D
DigiSAT Uplink Report
Guest
SatelliteGuys.US DishNetwork Uplink Activity Report - 4/15/2009 1:38pm - 74 changes
Uplink Comparison Range: 04/15/2009 01:10P - 04/15/2009 01:38P
Channel Additions:
216 - ION [MPEG2 SD] added to EchoStar7 119W TP 14 ConUS beam (A)
216 - ION [MPEG4 SD] added to Echostar6 72.7W TP 31 ConUS beam (A)
217 - IONW [MPEG2 SD] added to EchoStar7 119W TP 20 ConUS beam (NA)
5153(14) - KFJX [MPEG4 HD] added to Echostar12 61.5W TP 13 Area 8 beam (NA)(Pittsburg, KS-FOX)
5260(12) - KDRV [MPEG4 HD] added to Ciel-2 129W TP 16 Spotbeam ?? (NA)(Medford, OR-ABC)
5261(10) - KTVL [MPEG4 HD] added to Ciel-2 129W TP 16 Spotbeam ?? (NA)(Medford, OR-CBS)
5262(5) - KOBI [MPEG4 HD] added to Ciel-2 129W TP 16 Spotbeam ?? (NA)(Medford, OR-NBC)
5263(26) - KMVU [MPEG4 HD] added to Ciel-2 129W TP 16 Spotbeam ?? (NA)(Medford, OR-FOX)
5422(422) - SUN [MPEG4 HD] added to Ciel-2 129W TP 25 ConUS beam (A) (H)
5423(423) - FOXFL [MPEG4 HD] added to Ciel-2 129W TP 25 ConUS beam (A) (H)
6101 - SUNTV [MPEG2 SD] added to EchoStar1 148W TP 11 ConUS beam (A) (H)
6102 - TVCI [MPEG2 SD] added to EchoStar1 148W TP 07 ConUS beam (A) (H)
6103 - BLUE [MPEG2 SD] added to EchoStar1 148W TP 27 ConUS beam (NA)
6105 - K TV [MPEG2 SD] added to EchoStar1 148W TP 25 ConUS beam (NA)
6106 - RTVI [MPEG2 SD] added to EchoStar1 148W TP 07 ConUS beam (A) (H)
6107 - ANTGO [MPEG2 SD] added to EchoStar1 148W TP 27 ConUS beam (NA)
6109 - ANTEN [MPEG2 SD] added to EchoStar1 148W TP 27 ConUS beam (NA)
6110 - INTER [MPEG2 SD] added to EchoStar1 148W TP 29 ConUS beam (NA)
6111 - HTBA [MPEG2 SD] added to EchoStar1 148W TP 07 ConUS beam (A) (H)
6112 - RTVI+ [MPEG2 SD] added to EchoStar1 148W TP 07 ConUS beam (NA)
6125 - MUSIK [MPEG2 SD] added to EchoStar1 148W TP 29 ConUS beam (A) (H)
6127 - QTV [MPEG2 SD] added to EchoStar1 148W TP 29 ConUS beam (A) (H)
6128 - ERT [MPEG2 SD] added to EchoStar1 148W TP 07 ConUS beam (A) (H)
6131 - GLBL1 [MPEG2 SD] added to EchoStar1 148W TP 03 ConUS beam (A) (H)
6132 - ISMOV [MPEG2 SD] added to EchoStar1 148W TP 03 ConUS beam (A) (H)
6133 - ISRLI [MPEG2 SD] added to EchoStar1 148W TP 01 ConUS beam (NA)
6136 - ARYDI [MPEG2 SD] added to EchoStar1 148W TP 09 ConUS beam (A) (H)
6137 - ARYOW [MPEG2 SD] added to EchoStar1 148W TP 29 ConUS beam (NA)
6138 - GEOTV [MPEG2 SD] added to EchoStar1 148W TP 03 ConUS beam (A) (H)
6139 - INDMU [MPEG2 SD] added to EchoStar1 148W TP 27 ConUS beam (A) (H)
6140 - INDUS [MPEG2 SD] added to EchoStar1 148W TP 27 ConUS beam (A) (H)
6141 - PTV [MPEG2 SD] added to EchoStar1 148W TP 09 ConUS beam (NA)
6799(77) - HIDEF [MPEG2 SD] added to EchoStar11 110W TP 02 ConUS beam (NA)
8025(30) - KPXN [MPEG2 SD] added to EchoStar7 119W TP 20 ConUS beam (NA)(San Bernardino, CA-N/A)
8994(50) - KBTX [MPEG2 SD] added to EchoStar7 119W TP 05 Texas beam (NA)(Bryan, TX-CBS)
8994(50) - KBTX [MPEG4 SD] added to Echostar12 61.5W TP 11 Area 3 beam (NA)(Bryan, TX-CBS)
Channel Removals:
212 - CSPN2 (A) removed from EchoStar11 110W TP 19 ConUS beam
212 - CSPN2 (A) removed from Echostar6 72.7W TP 07 ConUS beam
216 - C&T (A) removed from EchoStar11 110W TP 19 ConUS beam
216 - C&T (A) removed from EchoStar3 61.5W TP 27 ConUS beam
217 - DISH (A) removed from EchoStar11 110W TP 19 ConUS beam
217 - DISH (A) removed from Echostar12 61.5W TP 23 ConUS beam
578 - BRDGS (A) (H) removed from EchoStar1 148W TP 09 ConUS beam
578 - BRDGS (A) (H) removed from EchoStar3 61.5W TP 08 ConUS beam
911 - ANTRA (A) (H) removed from EchoStar1 148W TP 27 ConUS beam
912 - RYTHM (A) (H) removed from EchoStar1 148W TP 27 ConUS beam
6153 - LTD16 (NA) removed from EchoStar11 110W TP 19 ConUS beam
6153 - LTD16 (NA) removed from Echostar6 72.7W TP 07 ConUS beam
8174 - KXVA (A) (H) removed from Echostar12 61.5W TP 07 Area 3 beam(Abilene, TX-FOX)
Channel Moves:
592 - RTVI [MPEG2 SD] moved from EchoStar1 148W TP 07 ConUS beam to EchoStar1 148W TP 11 ConUS beam (A)
594 - HTBA [MPEG2 SD] moved from EchoStar1 148W TP 07 ConUS beam to EchoStar1 148W TP 11 ConUS beam (A)
595 - TVCI [MPEG2 SD] moved from EchoStar1 148W TP 07 ConUS beam to EchoStar1 148W TP 11 ConUS beam (A)
603 - ERT [MPEG2 SD] moved from EchoStar1 148W TP 07 ConUS beam to EchoStar1 148W TP 11 ConUS beam (A)
620 - GEOTV [MPEG2 SD] moved from EchoStar1 148W TP 03 ConUS beam to EchoStar1 148W TP 11 ConUS beam (A) (H)
621 - ARYDI [MPEG2 SD] moved from EchoStar1 148W TP 09 ConUS beam to EchoStar1 148W TP 11 ConUS beam (A) (H)
662 - QTV [MPEG2 SD] moved from EchoStar1 148W TP 29 ConUS beam to EchoStar1 148W TP 11 ConUS beam (A) (H)
663 - MUSIK [MPEG2 SD] moved from EchoStar1 148W TP 29 ConUS beam to EchoStar1 148W TP 11 ConUS beam (A)
674 - INDMU [MPEG2 SD] moved from EchoStar1 148W TP 27 ConUS beam to EchoStar1 148W TP 11 ConUS beam (A) (H)
678 - INDUS [MPEG2 SD] moved from EchoStar1 148W TP 27 ConUS beam to EchoStar1 148W TP 11 ConUS beam (A) (H)
702 - GLBL1 [MPEG2 SD] moved from EchoStar1 148W TP 03 ConUS beam to EchoStar1 148W TP 11 ConUS beam (A) (H)
703 - ISMOV [MPEG2 SD] moved from EchoStar1 148W TP 03 ConUS beam to EchoStar1 148W TP 11 ConUS beam (A) (H)
Channel Package Flag Changes:
602 - PNJBI [MPEG2 SD] - Anik F3 118.7W TP 26 ConUS beam changed to Available
727 - VIDIT [MPEG2 SD] - Anik F3 118.7W TP 29 ConUS beam changed package flags (A)
730 - RAINW [MPEG2 SD] - Anik F3 118.7W TP 28 ConUS beam changed package flags (A)
775 - AGAPY [MPEG2 SD] - Anik F3 118.7W TP 19 ConUS beam changed to Available
809 - JUS [MPEG2 SD] - Anik F3 118.7W TP 29 ConUS beam changed package flags (A)
5150(6) - WDAY [MPEG4 HD] - Ciel-2 129W TP 09 Spotbeam 8 changed to Available (H)(Fargo, ND-ABC)
5153(23) - WPFO [MPEG4 HD] - Echostar12 61.5W TP 09 Area 6 beam changed to Available (H)(Waterville, ME-FOX)
5173(15) - KXVA [MPEG4 HD] - Echostar12 61.5W TP 07 Area 3 beam changed to Available (H)(Abilene, TX-FOX)
7048(3) - WBEP [MPEG2 SD] - Ciel-2 129W TP 06 Spotbeam 25 changed to Available (H)
8746(50) - KHBBD [MPEG2 SD] - EchoStar10 110W TP 29 Spotbeam 37 changed to Available (H)
Channel Renames:
8124 - KLDO3 - EchoStar10 110W TP 27 Spotbeam 17 renamed to KXOF (NA)(Laredo, TX-UNI)
9645(99) - LF1 - EchoStar11 110W TP 10 ConUS beam renamed to SONY (A)
9645(99) - LF1 - EchoStar8 77W TP 29 ConUS beam renamed to SONY (A)
Channels in the system: 6428
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
Channel Additions:
Channel Removals:
Channel Moves:
Channel Renames:
