lmb set up
cheito
85
usa
i have a dish 301 reciver have two dish 500 one looking at 119,110 and the other at 61.5 and have a dish pro lnb the one that has the two otlets one on each side and the build in switch my question is i know that the outlet that says 119 i know that that goes into the reciver and i can get the 119,110 together now the other side that says 110 could i use that to get 61.5 ??? i havent hooked it up cause i am scared so need help thanks.
No you need an SW21 switch to connect all 3 satellites.
JVI 35-SW21X 2-in-1 Multi-Dish Switch
  • SW21X Satellite Multi-Dish Switch.
  • Used for Dish Network and Bell Expressvu.
  • Works along with the SW21 to connect 3 dishes and one
  • receiver to pick up signals from 3 SATs at 110 and 119 and 148 or 61.5.
  • It can also work alone as a regular SW21 switch.
  • Solder-backed
  • 950 MHz–2150 MHz
  • Compatible with Legacy DISH Systems
a dp21 can be used to combine a DP Twin and a DP single/dual for 110/119 and 61.5 or 148 or 129 to one receiver
A DP34 is needed for more than 2 receivers
huh, never thought of doing that. i also never thought of using a dpp twin to aim at 61.5 as a solo orbital, but i see people do that a lot. i guess that works too.
