Hi all.I'm using a fortec ultra and have been trying for a while to get rtn on 83w.But no such luck. I've tried scanning by using power scan transponder scan etc.I get strong signals on the transponders because I use a 33" dish.I even entered the freq. and transponder and symbol rate directly. The only channel I get on this sat is the nbc colour bar channel,thats all .Anyone have any Idea..Thanks
Enter the TP info manually. (I use 11734H, 4445) YMMV
Fine tune the LNBF skew. Adjust it until you get the best quality.
Fine tune dish aiming.
If all that fails... Get a separate dish, pointed at 83W to make the fine tuning easier.
That's what I did. It was worth it.
My setup:
Receiver - Fortec Mercury II
Quality threshold is about 30% IIRC. (below which the receiver will not lock and give a picture)
Fortec 90cm dish on a motor
pointed at 83W
11775H - 50%-54% Q
11734H - Nothing
ADTH 87cm fixed dish
pointed at 83W
11775H - 60%-70% Q
11734H - 40%-42% Q
If you have a single dish on a motor, I feel for your situation. In my opinion, setting up a motorized Ku dish well is difficult to do. (at least, I'm not very good at it.)
edit - Anyway, with that marginal motor dish setup, I can get everything else from 74w to 129 w.
There has been a lot of discussion about this. Do a search for threads about this for more info.
