D
DigiDish Uplink Report
Guest
SatelliteGuys.US DishNetwork Uplink Activity Report - 5/21/2009 1:59am - 37 changes
Uplink Comparison Range: 05/21/2009 01:44A - 05/21/2009 01:59A
Channel Additions:
5720 - HD1 [MPEG4 HD] added to EchoStar11 110W TP 17 ConUS beam (NA)
5721 - HD2 [MPEG4 HD] added to EchoStar11 110W TP 17 ConUS beam (NA)
5722 - HD3 [MPEG4 HD] added to EchoStar11 110W TP 17 ConUS beam (NA)
5723 - HD4 [MPEG4 HD] added to EchoStar11 110W TP 17 ConUS beam (NA)
5724 - HD5 [MPEG4 HD] added to EchoStar11 110W TP 17 ConUS beam (NA)
5725 - HD6 [MPEG4 HD] added to EchoStar11 110W TP 17 ConUS beam (NA)
5726 - HD7 [MPEG4 HD] added to EchoStar11 110W TP 17 ConUS beam (NA)
5727 - HD8 [MPEG4 HD] added to EchoStar11 110W TP 17 ConUS beam (NA)
Channel Removals:
4825 - TMP26 (NA) removed from EchoStar11 110W TP 17 ConUS beam
9428 - TMP20 (NA) removed from EchoStar11 110W TP 07 ConUS beam
9430 - TMP21 (NA) removed from EchoStar11 110W TP 07 ConUS beam
9445 - TMP22 (NA) removed from EchoStar11 110W TP 07 ConUS beam
9447 - TMP23 (NA) removed from EchoStar11 110W TP 13 ConUS beam
9448 - TMP24 (NA) removed from EchoStar11 110W TP 13 ConUS beam
9474 - TMP25 (NA) removed from EchoStar11 110W TP 13 ConUS beam
Channel Moves:
374 - FTV [MPEG4 HD] moved from EchoStar3 61.5W TP 30 ConUS beam to EchoStar3 61.5W TP 20 ConUS beam (A)
535 - HDPPV [MPEG4 HD] moved from EchoStar11 110W TP 17 ConUS beam to EchoStar11 110W TP 13 ConUS beam (A)
536 - HDPPV [MPEG4 HD] moved from EchoStar11 110W TP 17 ConUS beam to EchoStar11 110W TP 13 ConUS beam (A)
537 - HDPPV [MPEG4 HD] moved from EchoStar11 110W TP 17 ConUS beam to EchoStar11 110W TP 13 ConUS beam (A)
540 - HDPPV [MPEG4 HD] moved from EchoStar11 110W TP 17 ConUS beam to EchoStar11 110W TP 13 ConUS beam (A)
4105 - USA [MPEG4 HD] moved from EchoStar11 110W TP 17 ConUS beam to EchoStar11 110W TP 07 ConUS beam (A) (H)
4122 - SCIFI [MPEG4 HD] moved from EchoStar11 110W TP 17 ConUS beam to EchoStar11 110W TP 07 ConUS beam (A) (H)
4271 - FTV [MPEG4 HD] moved from EchoStar3 61.5W TP 30 ConUS beam to EchoStar3 61.5W TP 20 ConUS beam (A) (H)
4806 - TMP36 [MPEG4 HD] moved from Ciel-2 129W TP 25 ConUS beam to Ciel-2 129W TP 27 ConUS beam (NA)
5304 - FTV [MPEG4 HD] moved from EchoStar3 61.5W TP 30 ConUS beam to EchoStar3 61.5W TP 20 ConUS beam (A) (H)
5328 - USA [MPEG4 HD] moved from EchoStar11 110W TP 17 ConUS beam to EchoStar11 110W TP 07 ConUS beam (A) (H)
5329 - SCIFI [MPEG4 HD] moved from EchoStar11 110W TP 17 ConUS beam to EchoStar11 110W TP 07 ConUS beam (A) (H)
5376 - TMP11 [MPEG4 HD] moved from Ciel-2 129W TP 25 ConUS beam to Ciel-2 129W TP 27 ConUS beam (NA)
5502 - USA [MPEG4 HD] moved from EchoStar11 110W TP 17 ConUS beam to EchoStar11 110W TP 07 ConUS beam (A) (H)
5503 - SCIFI [MPEG4 HD] moved from EchoStar11 110W TP 17 ConUS beam to EchoStar11 110W TP 07 ConUS beam (A) (H)
5780 - HDSKD [MPEG4 HD] moved from EchoStar3 61.5W TP 20 ConUS beam to EchoStar3 61.5W TP 30 ConUS beam (NA)
5791 - HDSKD [MPEG4 HD] moved from Ciel-2 129W TP 27 ConUS beam to Ciel-2 129W TP 25 ConUS beam (NA)
5792 - HDSKD [MPEG4 HD] moved from Ciel-2 129W TP 27 ConUS beam to Ciel-2 129W TP 25 ConUS beam (NA)
5904 - DRMT8 [MPEG4 HD] moved from EchoStar11 110W TP 17 ConUS beam to EchoStar11 110W TP 13 ConUS beam (NA)
9264 - WSIU [MPEG2 SD] moved from EchoStar11 110W TP 21 ConUS beam to EchoStar11 110W TP 22 ConUS beam (A) (H)(Carbondale, IL-N/A)
9431 - USA [MPEG4 HD] moved from EchoStar11 110W TP 17 ConUS beam to EchoStar11 110W TP 07 ConUS beam (A)
9432 - SCIFI [MPEG4 HD] moved from EchoStar11 110W TP 17 ConUS beam to EchoStar11 110W TP 07 ConUS beam (A)
Transponder Changes:
Echostar12 61.5W TP 23 ConUS beam changed from 21500 8PSK 2/3 to 20000 QPSK 5/6
Channels in the system: 6619
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
Channel Additions:
Channel Removals:
Channel Moves:
