Hi all, I am new here so if this has been covered I am sorry, I looked for a search function but did not find one so here is my question.
I hook-up dishes for a FTA korean network, one of my customers just put in a system that has 2 converter boxes hooked up to a single output LNB, the feed line from the LNB splits and then each one run to a box which is on its own line by its self (in other words they are NOT hooked up in series). What I found is that if one of the boxes is turned off the other box registers no signal at all, if you disconnect the line to one of the boxes again the 2ed box "looses" all signal. I was wondering if this is an anti-hacking feature where each box has to "see" the other one before they will work so someone cant order 2 boxes (the 2ed box is alot cheeper per month then the first one) and give the 2ed box to a friend? These boxes have the plastic card with the computer chip in them to un-scramble the signal.
:up
