So for the record, all the dual tuners boxes that we have right now are dual HD *tuners*, there are not dual HD *output's* though.
I know that is what you were asking, for dual HD output, but both tuners in all the dual HD boxes can record HD shows, it's just that HD will only output on TV1
Getting the HD signal to a distant TV is not inexpensive.Can someone educate me on what the limitations are for dual tuner HD?
Depends what you call expensive and what you mean my distant. You can get quality 40ft HDMI cables for about $30. That is considerably cheaper than paying some monthly fee for an extra HD DVRGetting the HD signal to a distant TV is not inexpensive.
1) Because it would make the boxes cost more (because I doubt the chips inside can support streaming two HD-quality videos).Why not have a second HDMI or set of component outs for those that want to run the longer cables to other rooms?
what are you guys doing to control the tv1 output in the remote room???
Technical limitations aren't there, but practical limitations trump most everything in consumer electronics gear.So I guess there are no technilogical limitations to having dual independant HD output.
Because it is relatively expensive compared to the $15 store-bought 50' coax that the old timers and cable sufferers are used to. Imagine what they would charge at Best Buy for a 50' HDMI cable if the 12' version is $99.99 Blue Jeans and Monoprice remain relatively well kept secrets. All of the sudden that $7 charge doesn't seem so bad.Why not have a second HDMI or set of component outs for those that want to run the longer cables to other rooms?
Technical limitations aren't there, but practical limitations trump most everything in consumer electronics gear.Because it is relatively expensive compared to the $15 store-bought 50' coax that the old timers and cable sufferers are used to. Imagine what they would charge at Best Buy for a 50' HDMI cable if the 12' version is $99.99 Blue Jeans and Monoprice remain relatively well kept secrets. All of the sudden that $7 charge doesn't seem so bad.
Just because you can do something on paper doesn't mean that it is optimal or even nominal.
Finally, STL's point about the chipset not necessarily supporting two HD streams should not be ignored.
Your lack of vision doesn't change the physics or the economics of the situation. When people find out that it is going to cost $100 just for a cable to connect their new toy, they're not amused. See more at XBox 360 HD cabling.I don't foresee an electronics manufacturer being concerned that Best Buy is ripping people off on cables as a limitation on adding features to a product.
A pretty relevant case in point is DIRECTV's HR21 Pro HD DVR. It feeds a single signal through either HDMI and Component -OR- fiber optic connection. The mating part of the fiber optic connection (Owlink FO2800DTV, not included) is not a large fraction less expensive than the receiver itself (which could only be purchased). They are both still available and being blown out at somewhere around cost.
