what can you get on small dish
queeny
43
south carolina
due to econamy my son ish turning off dishnetwork I bought new receiver if he were to use dish and i give him my old receiver is there much he could get with the small dish
depending on what satellite(s) you dish is pointed at (I will assume 110W and 119W) you will get NASA TV, ION, and barker channels (Dish network info channels)
Other then that, not much else.. Again, assuming what I stated before, the type of LNB(s) you have on your dish are not compatible with any other satellites except for the the dish network satellites (Echostar) and Bell TV (Nimiq). You would need a bigger dish and a Linear LNB for the other satellites like the Galaxy satellites or AMC Satellites. The LNB(s) you have are circular
Now... I am new to this FTA hobby so hopefully someone can clarify this so I am not giving you the the wrong info
On 119W ....ION, NASA and Angel One are in the clear. If you change the LNB to a linear one, you can get 3ABN on 101W with that small dish. I am talking a 18" Dish here...BTW. Also 95W, 72W and 123W might be possible.
if you have not looked into over the air tv check out tvfool.com.
I have made some antennas using coat hangers, wood, and foil for cheap.
A add on craig's list for dishs may yeald some. Also freecycle may get some too.
Good luck and keep us posted.
sent from a ipaq
ATSC tuner in Satellite Receiver
Enter to Win: Sadoun Bandstacked KU LNBF - End 10/31/09
