 Hi, I'm new to this Forum. I did a 'forum search' to see if my question(s) were already answered here but could find same, so here I go:
 Hi, I'm new to this Forum. I did a 'forum search' to see if my question(s) were already answered here but could find same, so here I go:I have a standard Dish500 antenna on my shed. There is a dual "Digital LNBF" on it and this LNBF is covered by a single plastic housing rather than the type that look like 2 different "heads. It is # BS1D1UP201M with two co-ax connectors lettered A & B on the unit. Right now there are two RG6 leads attached to them which are combined into "one" by a SW21 switch. From there, the single cable goes to my single receiver (DP301)
I also have a "spare" Dish500 with a different DUAL LNBF on it: this one looks like two separate single LNBs combined side by side # BS1H3UP201M.
This one has FOUR co-ax connections, of which (the outer) TWO were previously hooked up on a friends home. This one also has the wrap around SD antenna on it with a combining type of switch labelled TERK plus a SW21 switch.
My first question is: Are both/either of the above LNBFs compatible with my adding another receiver ..would I be able to simply take a line from each Individual (A&B) and run one to each receiver -
[or is "A" for ONE of 110/119 and B for the other (only)] ?
If it can be done, this would have me remove the SW21 switch I assume.
2. Would either the 2 or 4 co-ax connector models above be "better" to use than the other ?
3. I see 'used' receivers for sale on Craigslist etc (like VIP 222, VIP 622). Now that "DISH" is following DirecTVs lead and is "leasing" equipment, some of this stuff for sale may not be the actual property of the seller. I'd hate to buy a used DVR only to find out that it 'really' belongs to DISH and have them decline to add it to my account, or worse, demand it BACK. Is it possible to take the receiver/card numbers down and call DISH and find out if they will simply add same to my account (like I did when I U/G to the DP301 from my first original Model 1000) without any kind of 'fee' ?
4. If I did get a HD receiver (like the 222/622) will those work with the above DISH500 with the LNBFs noted ?
thanks in advance for any help you can provide
A
PS: I might add that I'm out of the country for half a year so I shut down my Dish account and restart it each November. DISH isnt too happy with my account not being on the 12/24 month commitment but they will 'sell' me the Bronze 100 for $ 34.99/mo. They aren't of course interested in U/G my equipment or service except for a FEE which I'm not prepared to pay.
