Photos Of General Instrument HDD-1000 High Definition Decoder
wallyhts
Staff member
HERE TO HELP YOU!
3,219
448
Hi,
I used to have one of those. But, the peice of junk had the dreaded StarzHD drop-out problem.
P.S. resize your pictures
Please use the attachment option next time to make the pics thumbnails. Then folks can click to see the full size
Thanks!
What receiver were you using?
Thanks!
Thanks for doing that will do on next post.
Do you know the pinout from the MMAP Port to HSI input on HDD-1000?
I also have a DSR 920.
Thanks kbghdg,
I will try DB9
4 - HS+
9 - HS-
5 - Gnd
If that does not work i will switch 4 and 9.
Thanks kbghdg,
I will try DB9
4 - HS+
9 - HS-
5 - Gnd
Yes, that should work. If i remember correctly that thing had relays in it that'll start clicking when not on a HD channel. I used BNC to RCA adapters to send the signal into my tv. Also, the picture wasn't perfectly centered on the display. I did get it for cheap though and i sold it cheap fast.:D
GI Super350i and 8' BUD
installation help
