We are told to not expect any CE's other than the R15/R16.
Specifically, the HR2x CE is cancelled.
I read it as a CE for R15 & 16![]()
maybe they totally want to f up the R15 & 16![]()
The interactive channels, such as the sports channels, do take longer to respond because they have more things running in the background (the score guide in the case of the sports channels). Try hitting exit when the message comes up to hit the red button and that usually stops the guide from running in the background. Your DVR should respond a little quicker.what the heck does "stability" mean?
like when you are on a sports channel and want to do anything it doesnt take as long?
I've noticed that....if I'm on MLB Net and I hit guide or another channel it takes too long to "think"
You can ignore it and it will go away, but it will always be running in the background this way you can hit the red button anytime. If you hit the exit button it will stop it all together and you cannot bring it up until you tune back to that channel or another sports channel.I see the red button in the corner disappear after a bit but hitting exit shuts it off (until I change the channel)?
I never knew that. I don't go to 101 very oftenand why does it show up on 101 too? That isnt a sports channel![]()
It showed up last night when I was watching the trailer park boys
edit: just took a pic
This is common, Not just on an interactive channel either. This is the Gripe I have with them.I've noticed that....if I'm on MLB Net and I hit guide or another channel it takes too long to "think"
I've noticed it for awhile also... on last weeks CE for my HR20 - 700... caps just taken.I see the red button in the corner disappear after a bit but hitting exit shuts it off (until I change the channel)?
