Your G-19 Signal Report is Needed
Signal Report 97W
Sky is Clear
Coolsat 7000, 1.0m QSat w/QPH-031
11789 V 28125 - SQ: 87
11836 V 20765 - SQ: 85
11842 H 22000 (new) - SQ: 90
11867 V 22000 - SQ: 86
11874 H 22000 - SQ: 89
11936 H 20000 - SQ: 88
11966 H 22000 - SQ: 88
12053 V 22000 - SQ: 89
12060 H 22000 - SQ: 92
12115 V 22425 - SQ: 85
12177 V 23000 - SQ: 89
Size of your dish: 30 inch
11789 V 28125 - 57
11836 V 20765 - 63
11842 H 22000 (new) - 66
11867 V 22000 - 63
11874 H 22000 - 66
11936 H 20000 - 57
11966 H 22000 - 43
12053 V 22000 - 66
12060 H 22000 - 66
12115 V 22425 - 43
12177 V 23000 - 63
Fortec 90cm, Invacom TWH-031, AzBox Elite
Northwest Ohio
11789 V 28125 - SQ: 69
11836 V 20765 - SQ: 68
11842 H 22000 (new) - SQ: 73
11867 V 22000 - SQ: 70
11874 H 22000 - SQ: 72
11936 H 20000 - SQ: 73
11966 H 22000 - SQ: 77
12053 V 22000 - SQ: 73
12060 H 22000 - SQ: 80
12115 V 22425 - SQ: 58
12177 V 23000 - SQ: 64
Submitted by: AcWxRADAR
LOCATION: Omaha, NE (~40 miles NW of the city proper as the crow flies)
RECEIVER: AZBox Premium
ANTENNA: GeosatPro 1.2M
LNBF: Invacom QPH-031
MOTOR: PowerTech DG-380
SWITCH: Chieta HD 4x1 DiSEqC (F = 900-2400 MHz, Insertion loss: 1.5 dB, Isolation: >30dB)
CABLE: ~300 feet of RG11 + ~50 feet of RG6 quad shield.
SATELLITE: 97°W Galaxy 19
LOS: OPEN and CLEAR
11789 V 28125 - SQ: 69%
11836 V 20765 - SQ: 64%
11842 H 22000 - SQ: 76%
11867 V 22000 - SQ: 67%
11874 H 22000 - SQ: 73%
11936 H 20000 - SQ: 74%
11966 H 22000 - SQ: 72%
12053 V 22000 - SQ: 72%
12060 H 22000 - SQ: 75%
12115 V 22425 - SQ: 61%
12177 V 23000 - SQ: 63%
Dish = Fortec 80CM
LNB = Invacom 031 Quad
Receiver = Sonicview 360 Elite
WX = Overcast
11789 V 28125 - SQ: 38
11836 V 20765 - SQ: 39
11842 H 22000 (new) - SQ: 18
11867 V 22000 - SQ: 43
11874 H 22000 - SQ: 16
11936 H 20000 - SQ: 15
11966 H 22000 - SQ: 32
12053 V 22000 - SQ: 48
12060 H 22000 - SQ: 43
12115 V 22425 - SQ: 43
12177 V 23000 - SQ: 47
Note: The tv picture on the 360 Elite does not pixelate until the signal drops below 5. This unit has a stingy signal meter when compared to most other receivers. Greg
G19 @ 97w
Location Western NY 45 miles south of Buffalo
Dish - Fortec 31"
Switch -35-TRDS8
Reciever- Fortecstar Dynamic
weather - clear
11789 V 28125 - SQ:56
11836 V 20765 - SQ:58
11842 H 22000 (new) - SQ:58
11867 V 22000 - SQ:52
11874 H 22000 - SQ:52
11936 H 20000 - SQ:49
11966 H 22000 - SQ:47
12053 V 22000 - SQ:60
12060 H 22000 - SQ:53
12115 V 22425 - SQ:50
12177 V 23000 - SQ:50
Dish - 7.5' unimesh
LNB - Geosat CK1 C/KU
Switch - diseq 2x1
Reciever- Pansat 3500
11789 V 28125 - SQ:60
11836 V 20765 - SQ:60
11842 H 22000 (new) - SQ:31
11867 V 22000 - SQ:45
11874 H 22000 - SQ:48
11936 H 20000 - SQ:45
11966 H 22000 - SQ:30
12060 H 22000 - SQ:60
12115 V 22425 - SQ:15
12177 V 23000 - SQ:60
I see something very interesting with the resullts from Larobpra and W_Tracy_Parnell and I . All of our sq's are very simular in this region .
Mississauga, ON
Motorized 6 ft C/Ku Gospell LNBF w/ 22khz and SW-21 switches
CS 8100HD after VBOX II
WX Partly Cloudy
11789V 1 %
11836V 10%
11842H 17%
11867V 9%
11874H 7%
11966H 4%
12053V 22%
12060H 24%
12177V 9%
Thanks Guys!
We have a few of the engineers looking at this thread and your input is VERY helpful!
Please keep the reports coming in for the next several days. We especially can use any signal reports from the Pacific / Atlantic provinces of Canada, Central America or the Caribbean. SatelliteAV Mexico will be reporting tomorrow, but initial reports from Cabo on the tip of the Baja indicate very good signal reports.
11789 V 28125 - SQ: 73
11836 V 20765 - SQ: 73
11842 H 22000 (new) - SQ: 76
11867 V 22000 - SQ: 69
11874 H 22000 - SQ: 75
11936 H 20000 - SQ: 69
11966 H 22000 - SQ: 69
12053 V 22000 - SQ: 75
12060 H 22000 - SQ: 76
12115 V 22425 - SQ: 69
12177 V 23000 - SQ: 73
Diamond 9000HD with a GeosatPro 90cm, generic LNB that came with my digiwave dish. DG380 motor, clear weather.
so here are some numbers from 101w at about 51.5n.
coolsat 8100 / 1m channelmaster gt-t40c linear lnb
11789 V 28125 - SQ: 85 / 99
11836 V 20765 - SQ: 85 / 99
11842 H 22000 (new) - SQ: 86 / 99 (3 video, 2 radio)
11867 V 22000 - SQ: 88 / 99
11874 H 22000 - SQ: 85 / 99
11936 H 20000 - SQ: 87 / 99
11966 H 22000 - SQ: 89 / 99
12053 V 22000 - SQ: 86 / 99
12060 H 22000 - SQ: 87 / 99
12115 V 22425 - SQ: 87 / 99
12177 V 23000 - SQ: 82 / 99
coolsat 8100 / 39" gospell / invacom qph-031
11789 V 28125 - SQ: 76 / 99
11836 V 20765 - SQ: 82 / 99
11842 H 22000 (new) - SQ: 75 / 85 (3 video, 2 radio)
11867 V 22000 - SQ: 74 / 99
11874 H 22000 - SQ: 76 / 99
11936 H 20000 - SQ: 75 / 99
11966 H 22000 - SQ: 75 / 99
12053 V 22000 - SQ: 75 / 99
12060 H 22000 - SQ: 75 / 99
12115 V 22425 - SQ: 75 / 97
12177 V 23000 - SQ: 73 / 99
cs 6k / 1m channelmaster / gt-t40c linear lnb
11789 V 28125 - SQ: 92 / 97
11836 V 20765 - SQ: 92 / 93
11842 H 22000 (new) - SQ: 95 / 88 (3 video, 2 radio)
11867 V 22000 - SQ: 92 / 91
11874 H 22000 - SQ: 97 / 94
11936 H 20000 - SQ: 97 / 94
11966 H 22000 - SQ: 97 / 94
12053 V 22000 - SQ: 93 / 93
12060 H 22000 - SQ: 96 / 90
12115 V 22425 - SQ: 92 / 90
12177 V 23000 - SQ: 90 / 90
coolsat cs6k / 39" gospell / invacom qph-031
11789 V 28125 - SQ: 85 / 90
11836 V 20765 - SQ: 87 / 90
11842 H 22000 (new) - SQ: 83 / 70 (3 video, 2 radio)
11867 V 22000 - SQ: 86 / 87
11874 H 22000 - SQ: 83 / 93
11936 H 20000 - SQ: 86 / 91
11966 H 22000 - SQ: 85 / 91
12053 V 22000 - SQ: 85 / 93
12060 H 22000 - SQ: 85 / 93
12115 V 22425 - SQ: 86 / 87
12177 V 23000 - SQ: 85 / 87
the 1m is behind 2 positioners, a grounding block, a 4x1 and 100 ft of coax.
the 39" is behind 1 f-f connector, a grounding block, an emp 4x1, an sg2100 and 100 ft of coax.
i could throw up a 36" dish if youd like me to test that for you.
crackt out,.
Tonight 11842 is fluctuating between 35 and 42 for me! All other transponders are within 3 points, many within 1 point, of the values I posted earlier (which I believe are very high, someone told me my receiver only goes to 75.) Same hardware, same weather except about 10 degrees cooler.
In Puerto Rico with a 4.5 cw 650
Note did not adjust the dish just went up last night and move it I can improve more!
11789 V 28125 - S80Q:59
11836 V 20765 - S75Q:60
11842 H 22000 (new) - S79Q:60
11867 V 22000 - S80Q:58
11874 H 22000 - S78Q:70
11936 H 20000 - S77Q:48
11966 H 22000 - S73Q:53
12053 V 22000 - S75Q:60
12060 H 22000 - S85Q:70
12115 V 22425 - S70Q:47
12177 V 23000 - S80Q:50
lnb that I used is a phillips freq is 10600 I had it in the closet for quite a while
I know that if I adjust I will get more!
Regarding Cabo San Lucas, Mexico levels.
I did extensive testing on C band as well as Ku-band while there in Oct 2008, and found that 97 West was among the strongest satellites in the sky, rivaling the "local" signals from SatMex on Ku-band. A 1-meter Primestar offset was able to break the 85% Quality mark on most transponders, using Traxis DBS-3500.
from 118w by 34.1n
Using the same lnb, multiswitch & receiver: a DMX522, Zinwell 4x4, Coolsat 7100 micro PVR w CS v1.16 FW.
76cm Winegard 1.2m Fortecstar
w PM900S mtr w DG380 mtr
S/Q S/Q
11789 v 28125 90/72 92/88
11836 v 20765 91/76 92/76
11842 h 22000 87/34 92/85 bouncing Q
11867 v 22000 91/78 92/89
11874 h 22000 87/38 92/85
11936 h 20000 92/43 92/86
11966 h 22000 91/52 92/88
12053 v 22000 91/83 92/89
12060 h 22000 91/64 92/87
12115 v 22425 90/79 91/85
12177 v 23000 91/80 92/87
From my location I'd surmise that at least a 1 m dish is needed for quality.
Coolsat 5000, WSI9036 with InvacomQPH-031,
West Arkansas, near OK border.
11789V 28125-SQ: 75%
11836V 20765-SQ: 76%
11842H 22000-SQ: 72-73%
11867V 22000-SQ: 73%
11874H 22000-SQ: 77%
11936H 20000-SQ: 76%
11966H 22000-SQ: 73%
12053V 22000-SQ: 76%
12060H 22000-SQ: 78%
12115V 22425-SQ: 73%
12177V 23000-SQ: 75%
90cm fortec star,invacom lnb,viewsat max & pansat 250.
Chicago,IL
11789 V 28125 - SQ-(67%-VS) (73%-PS)
11836 V 20765 - SQ-(65%-VS) (71%-PS)
11842 H 22000 - SQ-(54%-VS) (53%-PS)
11867 V 22000 - SQ-(66%-VS) (72%-PS)
11874 H 22000 - SQ-(70%-VS) (78%-PS)
11936 H 20000 - SQ-(70%-VS) (81%-PS)
11966 H 22000 - SQ-(71%-VS) (81%-PS)
12053 V 22000 - SQ-(68%-VS) (80%-PS)
12060 H 22000 - SQ-(73%-VS) (83%-PS)
12115 V 22425 - SQ-(63%-VS) (69%-PS)
12177 V 23000 - SQ-(68%-VS) (76%-PS)
GEOsatPRO 90cm motorized, tested with a Fortec Star Lifetime Ultra, Captive Works 600S Premium, Pansat 9200HD and Coolsat 6100 Private.
Location Northern Kern County Desert area So Cal.
One thing I've noticed is that my motorized 36" GeosatPRO dish has to be nudged a few steps WEST to peak the 11842 signal on G-19 but as I do I lost signals on the 11966, 12115 & 12177 while others dropped to lower levels so I positioned the motor to a happy medium between the two. It seems that the new frequency is off skew or outside the beam. This is my best way to describe it.
If I fine tune the dish position to the new 11842 freq I have about 69 -72% quality in So Cal but when I fine tune to the other resident frequencies the 11842 will drop to about 34% or less quality.
Kentville, Nova Scotia, Canada
Starchoice 75E - Quad Linear lnb
Dreambox 500-S
Current Conditions - Cloudy
11789 V 28125 - SQ: 84%
11836 V 20765 - SQ: 84%
11842 H 22000 - SQ: 78%
11867 V 22000 - SQ: 86%
11874 H 22000 - SQ: 79%
11936 H 20000 - SQ: 79%
11966 H 22000 - SQ: 81%
12053 V 22000 - SQ: 86%
12060 H 22000 - SQ: 79%
12115 V 22425 - SQ: 84%
12177 V 23000 - SQ: 85%
We have4 noticed something similar in NorCal as well. If 12115 V, 11966 H or 12177 V is peaked, the dish needs to be bumped west to peak for 11842 H or 12152 H.
Is anyone else able to confirm this in their region?
Yes I have to bump the dish to bring some TPs up to max levels. Not sure right now which way though. And as I said before, I haven't been able to get 11966 H good enough to watch yet at all, except when I was out at the dish the other day and cupped my hand around the feedhorn on the LNB.
Recent Acquisition. Spring Project?
nbc sat mux 3 & 4 audio?
