Radio Signals
Diamond Jim
4,453
561
The Boilermaker State (#19)
I am looking for any radio mux between 55W and 139W that has early 1960s to mid 1970s Classic Rock, 1950s to 1970s Classic Bules and Classical Symphonies. Yes, I have a long range of musical tastes. I am currently listening to the mux on 101W. They play good stuff but it it is not exactly what I am looking for. I guess you would say I am looking for something like the old fashioned "underground" rock stations.
I think you might like WPR Sounds on 99. They play everything from old-school country to bluegrass to classic rock, some modern rock and what I would consider "coffee shop rock." You could take it for a test drive here:
Reactions: lost_mesa
Thanks Numb
Thanks Numb. Do you have an FR and SR or is this a scan and see what I get operation?
Thanks. I have never seen a symbol rate with only 3 digits.
The Octagon SF 8008 and the Linkbox 9000 would not touch that low SR manually entered or blind scan. I did get quite a few FRs with low SRs but they were all 4 digit. Thanks for the effort.
Reactions: comfortably_numb
105 W C band has the Westwood One mux, it's pretty good but has commercials and more oriented towards FM audiences (that's what the C band feed is for to begin with). It's a really good alternative to local FMs if they either suck (my area has generally good FM stations) or only air good stuff part of the time. (I use it for Classic Rock/Classic Country when local stations are airing ballgames :( ) Then there's AM radio if you're desperate :clapping
The 101W Ku mux is pretty good (no commercials to boot!) but it's a smidge off of what I like too. WPR Classical lately has been one I listen to quite a bit, very relaxing.
GT media V9 (what I have) will tune low symbol rates fairly reliably, if you have a good LNB
I'll give 105W a try, thanks.
I tried using my GT Media V9 Prime to receive the Westwood One transponder on 105W C. It receives the signal but I can't receive any of the audio channels. Using my Edision OS Mio+, I can receive the audio channels fine. I heard sports talk, country, jazz, classical, older pop hits, etc.
So I think I manually entered the Audio PIDs for the radio channels I cared about, all the other radio channels I just scanned in.
looks like GT Media has left the satellite receiver business
FCC Votes to Clear at Least 100MHz of Upper C-Band Spectrum
