Echostar 14 update
TheKrell
A mighty and noble race originating on Altair IV.
38,819
46,481
Fairfax, VA
I wonder if they have a way to cheaply convert an QPSK box to 8PSK?
Interesting question for us hardware buffs. I think they could convert a 301 into a 311 by swapping out the tuner module. If the form factor isn't identical already, I'll bet there are enough 301s out there to make a special run of 8PSK tuners that would be.
drdroo
1,195
Bangor, ME USA
IIRC, that was all soldered. Could that possibly be cost effective?
It may be depending on if there's a pin compatible chipset to swap out. Depending on how many are out there, they could probably get such a chipset custom fabbed.
EDIT: Probably not cost effective in the US, but this kind of refurbishing work could probably be cost effective overseas.
digiblur
14,190
4
Louisiana
Don't most of the modern MPEG-2 receivers support 8PSK already? I thought I read something like that somewhere that Dish had this advantage over their competitor.
I know quite a few of the later SD DVR's are. The rebadged older 811's are. 311's etc.
I think we will start to see the higher tier channels move to 8PSK probably by the end of this year. Or quite possibly they will do it by DMA's. There are already some DMA's requiring 8PSK receivers even though they are SD MPEG2.
TheKrell
38,819
46,481
Fairfax, VA
The only other possibility for saving these receivers is to ship them to another country that's still using QPSK mpeg-2. Mexico perhaps? This would need new firmware, which process is nearly free. Another possiblity is a reflash to turn them into FTA receivers. ;)
digiblur
14,190
4
Louisiana
It isn't cost effective for two truck rolls though. If they are going to go through the effort of getting a customer to 8psk they are going to go mpeg4 too. If I remember correctly in those new dma's that required 8psk they also required mpeg4 even though the channels were mpeg2.
drdroo
1,195
Bangor, ME USA
It's probably cheaper just to continue with their existing receiver offerings since they've probably made enough of them now that they've justified their R&D as well as tooling expenses.
Each time you create a new product you have to pay a fair deal of up front costs to start manufacturing products. The more product you make, the more you dilute those costs.
DodgerKing
16,776
27
SoCal
It took them one week to do what it took Direct months to do. One has to question if there are any costs to doing something so quickly? Sometimes it is better to do something right vs fast.
Lt Disher
550
20
Iowa
It took them one week to do what it took Direct months to do. One has to question if their are any costs to doing something so quickly? Sometimes it is better to do something right vs fast.
It probably used more fuel to get it to its current position so quickly, but I don't think there is a right vs. fast argument here. It is either at its correct position or not. It can be both right and fast.
DodgerKing
16,776
27
SoCal
Not if you greatly diminish the life span by using too much fuel
DodgerKing
16,776
27
SoCal
And how much fuel, pray tell, did they use? Did they GREATLY diminish the life span of the satellite? I doubt it.
I don't know. That is why my point was in the form of a question in my first post and a conditional statement in my second. Comparing 2 months to 1 week, that is a huge difference.
harshness
18,893
4,066
Salem, OR
Sometimes, when you're using the right hardware, it is OK to go fast.
The SS/L FS-1300 is different in a number of respects from the Boeing 702HP. In addition to the station keeping ion setup similar to that of the 702, the FS-1300 also has a bipropellant engine for major moves. Rapidly moving the bird around doesn't deplete the ion system as always seems to be an overriding concern with rushing the Boeing birds.
