722 Freeze problem
doublek97
60
I have a 722 receiver and just started having a problem. When I firist turn on the television and the receiver, the receiver comes on but is unresponsive to the remote control for about a minute. Then, all of a sudden, it starts reacting to the commands. It is quite frustrating to say the least. I got the receiver and the HDTV last October and didn't have any problems whatsoever until just recently. Any ideas on what is causing it/how to end it?
Did you recently make any changes to the backlight settings on your TV?
Frequently the backlight on a LCD TV will emit IR when it is first turned on that interferes with the remote.
Try turning the TV on then wait 5 minutes and see if the 722 comes on and has the same behavior, if it does, it is the receiver, if it does not, it's the IR from the backlight.
I believe the auto setting on the backlight is the one that causes the problem.
:up:up:up
Thank you!
Thank you very much for the diagnosis! I changed the backlight setting and everything works great again! Problem solved!
The Official "Yay I got my 922 installed" thread.
the official 'Yay the server is too busy' thread
