Dish Earth
Ghpr13
3,212
Louisville, KY
I'm having a problem trying to locate the Dish Earth Channel. I have the Silver 200/HD/Platinum package. Other then the possibility that I'm totally blind or had a major loss of brain cells, what am I doing wrong?
Thanks,
Ghpr13:confused:
Hi, maybe your not receiving the satellite that it is on. I'm on the western arc and I think it is on the 110 satellite but I'm not sure. Can check later this evening. Not sure what satellite it might be on with the eastern arc. Later, DC
[COLOR=Black said:
TNGTony[/COLOR];2174614]Nope... I was wrong:
212 EARTH MPEG2 SD 110°W 21 QPSK (7/8) [SIZE=-2] ConUS beam[/SIZE] PREVIEW Available
212 EARTH MPEG4 SD 72.7°W 15 8PSK (2/3) [SIZE=-2] ConUS beam[/SIZE] PREVIEW Available
TNGTony,
So I should be able to get it correct? Why wouldn't it show up in my guide? I could have sworn I had it on before. Is it on all the time or just at certain times?
Ghpr13:confused:
TNGTony,
Ghpr13:confused:
Did you lock out 212 for any reason?
I went into "All Channels" on the guide and 212 doesn't show up. The only way to lock a channel out is to leave it "unchecked" in the guide set up correct?
Maybe your having LNB problems? Or switching problems.
I did a 611 test and everything came up OK. My guide updated complete with the new HD channels released today. I've only been with E* under a year so I'm still learning. How can I tell if I'm having LNB problems?
922 want let me watch recordings
List of HD Channels NOT Available on Dish Network: Version 2 Updated
