Questions about new locals on 72* sat
I live in the Bluefield/Beckley DMA, and have some technical questions.
I presently have a Dish 500 (110/119) to a model 508 dvr. The Dish 500 dish is mounted on galvanized fence post instead of on the house (only about 4 feet off the ground).
I know that my local channels are on the 72 degree sat., and they just became available, but I would like some info before ordering.
I know that I'll need a dish pointed at 72*, but I doubt that there is a dish assembly that will do the 110/119* plus 72* satellite and fit on the existing fence post. I'll also need a dvr/receiver upgrade to do mpeg4/hd, but my main concern is the dish(es) and coax.
What I don't know is will I need another coax running into my house, or is there a separate switch (or a built-in lnb/switch replacement) that will combine all of the sats down to one single coax? (assuming that the 72* dish will be separate)
The reason that I ask is that I may need to place the 72* dish some distance away from my existing 110/119* Dish 500 because of trees, new vinyl on house, location, etc. I'd also rather not have to run another coax into the house if I can help it, and I'd rather not put a wall mount up on my new vinyl siding.
There's a good spot that I could easily mount a separate 72* dish on a different fence post, but I'd estimate that would be up to 20 feet away from the existing Dish 500 assembly.
Any technical info that would help me with my question will be appreciated!
