922 and DLNA Media Steaming
elorion
23
Arizona
So I've been trying to get this working for awhile now. I can see the folders etc but when I open up one nothing is there. I've tried using Windows Media player streaming services and even PlayOn. All with no luck.....I have a Apple Extreme router. Anyone have any ideas on what setting I need to tweak to get this working? Thanks Elo
I'm using Windows Media and it's working for me. It's been a while since I set it up, but I do recall that I had problems streaming due to my firewall. Once I fixed that, it worked.
What'd ya do to fix it? The firewall that is. I see that Windows..Streaming is set to allowed for the LAN.Home etc
I'm using Comodo Firewall, so this may not help at all. Under Firewall, Advanced Options, you can set up Application Rules. I had to add Windows Media Player (wmpnetwk.exe). If you're using Windows Firewall, I'm not sure what the equivalent settings are.
The Windows Firewall should be turned off already if you enable the "Allow devices to connect to Media Player over the network" feature. If not, you should be able to just check it off as being allow in the list of applications.
DISHOnline testing legit?
if you cant get locals
