Can't get 72w - Other suggestions?
redilyn
After my problem setting elevation on my new (used) dish I have a new question.
I wanted to get 72w for the nbc mux, Previously I was unable to tune it in with my 75e channel master dishes. I could only ever get a little blip on the signal strength.
I recently acquired a 1m Starchoice dish which I believe is a winegard ds-3101 with a Starchoice linear lnb. Old style lnb, only one input.
I had hoped this dish would be sufficient but sadly I can only get 64% signal on 12055v. The tp listed as strongest in The List only gets 61%. In my experience with my dm500 I need minimum 75% for lock. I can hit 74w with 91% strength.
Is it possible to gain a substantial improvement in strength with a new lnb?
I have already tried tweaking with little success.
Is there another KU sat which someone might recommend? I already have 101w and I am not interested in the PBS stations.
I have tried the same dishes(1M and 75E) with no results but I think my problem is the 60' trees in my way.You may have better luck with another more sensitive LNB with lower noise (db).I'm near Amherst so you're marginally closer to the Clarke Belt.Do a little reading on the LNB stikies which might help you.G'luck
redilyn, i will try to help out with this one. i will say 72w is a weird sat. if you search here you will see that the settings of the dish pulls mixed responses. what i mean by this is if i set my motorized dish to pick up 63w-123w i tend to loose 72w. if i peak my true south which is 72w i loose anything above 103w. so for me i have to get 72w to the the point it just comes in (the settings on the dish elevation might be a little higher or lower than the other sats but not much. with all that said i am able to get 72w at 87 percent in the morning / sometimes daytime but then it fades in and out during the night. for lnbs i use a universal (horiz and vertical) one called a spitfire. they run about 14 bucks on ebay with shipping. if you are able 83w is good for retro tv and tuff tv. for my location i am normally able to lock at 80-90 percent always. i hope this helps.
AMC6 is my true south satellite so i spent alot of time with it.The NBC mux channels come in well here and a strong religious station also.I find some nice feeds on this satellite.
hi redilyn :)
in my experience changing lnbf's will not gain a SUBSTANTIAL increase in signal. in my experience the only way to get a SUBSTANTIAL increase in signal is to get a substantially bigger dish. i looked on the satbeams website and they recommend a 210cm (82.7in) minimum dish for that sat @ your location. you are on the fringe of their strong reception area it seems. by comparison the 74w horizons 2 sat shows a recommended 70cm (27.6 inch) minimum dish for your location.
as for another sat i like 30.0w hispasat for the very recent movies with english audio on the spanish station. however in my experience once i got the ku sats i found i wanted more so i ended up going with a c-band BUD instead and it was a great decision.
hope this helps
Kevin
I agree with other posters. You will most likely not see significant change with a new LNBF. In many cases there may be a decrease in Signal Quality when installing a LNBF with a scaler that is not designed specifically for the reflector.
A larger reflector should do the trick.
Don't get confused about the scalar rings;that's for C band,not ku.Some people say that certain? LNB's are more sensitive than others.I don't know, as I've been just using SC dishes/LNBs.A larger dish is always better for reception in all cases.Keep in mind that a cheap LNB may not be very good quality.Your best course is to read the LNB 'stickies' in the newbies' or FAQ sections plus the "How-to's".G'luck
????? Huh ?????
KU-band LNBFs usually incorporate scalers hidden behind the cosmetic plastics. Remove the feedhorn cover of a KU-band LNBF, you will find a scaler incorporated into the feedhorn on most models. KU-band LNBFs usually do not have the external and visible scalers that most associate with C-band systems.
Most ChanelMaster (example Primestar) 75e / 85e dishes have a feedhorn / scaler specifically designed for the dish. Substituting an off the shelf LNBF will likely not perform as well as the dish will be over-illuminated and picking up terrestrial noise off the dish edges.
I think you mean 120cm.
Guess I'm back in the market for another dish. I do know of a couple 4 footers, one that in 95% sure is not in use. If only I could bring myself to stop and visit these strangers LoL.
I will look into 30w, I don't think I have LOS there though. I have great LOS from 58w-129w but there is some very large trees in the way east of 58w. There is holes I can look through which I had found playing with a motorized dish a while back. It doesn't look good on dishpointer though.
I couldn't get rtv reliably before. I think its time to have another look.:)
redilyn said:
We are talking KU band, I just checked it says minimum 130cm :)
A point to also consider.... The EIRP footprints are based on fully saturated transponders and coverage varies between polarities. A larger dish is advised and may be required as most transponders are not operated in this configuration.
ya my bad. i had the c-band map loaded. when i did ku it said 150cm recommended with a 38dbw eirp.
Redilyn and Beavs,
I looked the EIRP information up through satbeams.com - this is the site that I have been using predominately if not exclusively for the most accurate information regarding EIRP values.
For the general area around Kentsville Nova Scotia, they are recommending a minumum dish size of 150 cm or 59.1 inches for the 38 dBw EIRP level that is estimated there.
I trust their recommendations within some measure of reasoning. I have found that I can obtain fair quality signals with certain combinations of dish/LNBF when they recommend a minimum that is larger than the dish that I am using. Therefore, some recommendations are left slightly to conjecture and dependant upon the combination of the dish and LNBF that is being used.
As Brian Gohl (SatelliteAV) elluded to, there is a definite advantage to matching the LNBF with the dish reflector. The Ku Band LNBFs have a "mini" scalar ring built in to the LNBF assembly. These are not noticeable unless you disect the LNBF, but they are present. Matching your LNBF to your dish is not an easy task to do on your own. It is best to ask the dish manufacturer to recommend the LNBF that is matched to their dish. They have done all the research in advance and that can save you a lot of headaches trying to figure it out yourself. Of course, if you are really into this hobby in a major way, this subject would (or may) be something that you would like to investigate in more depth for your own reasons - to learn for the sake of expanding your knowledge base. Well, you understand what I mean by that, but personally I don't get that involved with the engineering aspects in that fine of a sense.
Redilyn, from my own personal experience with the Winegard DS3101 dish, I found that this dish was very sensitive to the alignment with the satellite when I used it with the Invacom QPH-031 LNBF. When I did have it aligned perfectly, the signal quality was exceptional, but it was a very fine window of alignment and if I just tweaked the dish or the LNBF slightly, I nearly lost the signal altogether. It was very touchy.
I honestly had better luck with my Winegard DS2076 (76 cm) dish and the Invacom QPH-031 LNBF as opposed to the DS3101 (1 M) dish with the identical LNBF. I have now been using a 1.2 M GeosatPro dish with the Invacom QPH-031 and it is slightly more effective and efficient than either Winegard dish, but it is now also that much larger that I have some wind loading concerns which causes my signal to vary when we have strong, gusty and variable direction winds. The smaller 76 cm Winegard dish was much more forgiving in this regard, it allowed me a greater "fudge factor" for alignment.
Obviously, with the recommended dish size for your area for that particular satellite, you probably wouldn't want to use a 76 cm dish as that would most likely be too small (half of what is recommended by satbeam's site).
Just FYI, with my AZBox Premium Plus receiver, the 1.2 M GeoSatPro antenna and an Invacom QPH-031 LNBF and my location in the Omaha, Nebraska USA area, I am reading 88-94% quality from TP 12053 MHz (V) with a SR of 6890 Ks/S (which is the NBC MUX). Also, today, it is heavy overcast, drizzling rain from time to time and windy. For my area, Satbeams.com recommends a minimum dish size of 70 cm or 27.6 in (48 dBW EIRP value estimated).
I don't know how much my information will help you - if at all, but it will provide you with some data to ponder and compare and some ideas regarding what you might wish to research for your own system. I wish you fun and good luck!
RADAR
i can receive 58w and 43w with mini-c but not ku?
Diamond 9000HD locking up on 8PSK TPs
