You are very welcome Radar. Apparently I was not in the mood for long speeches and political tirades, lol
HD FAN,
How does this sound?......
IS FTA RIGHT FOR ME?(A description and guidance discussion inspired by HD FAN)
The answer to this question depends upon what kind of programming you desire to watch the most.
Do not expect to find movie channels or cable and specialty channels available here as those are mostly encrypted services and require a pay subscription.
In general, the channels that are available are primarily ethnical based, catering to specific countries or religions, some educational services or informative channels are available and a few novelty channels. The really good channels are dispersed over the various satellites located across the horizon. Some are only accessible in specific areas.
There is some really great programming available to those who opt to install a motorized system or a multi-dish system. It is almost required that you cover more than one satellite to obtain the most FTA opportunities (channels) that are available as there isn't just one satellite that will satisfy everyone's taste or pleasure in one package.
If you are just out to view TV for pleasure, you should investigate the OTA channels that are accessible in your location first. These may be all that is needed for you without subscription fees. If you don't mind some extra work and expense, you can delve into the hobby of FTA satellite TV.
This whole notion of FTA is just a hobby, it is not meant to be a replacement for Dish Network or DirecTV or any other subscription service. You must understand that before you begin, otherwise you may be disappointed.
In general, the system you set up should consist of at least a 90cm dish reflector for Ku band satellites, a trusted IRD / STB or receiver (preferably with blind scan capabilities).
Equipment costs may run near $200. For advanced Ku only systems, you could spend $400 to $1000 if you have a mind to. The price of the receiver is the most variable component. The cost of a H-H motor for a Ku band system may run from $70 to $120, but the receiver cost may vary between $50 and $500.
The cable and switches you might want are all peripheral support equipment. Their cost is minimal compared to the major components required… Which are the receiver, the dish, the LNBF (and the motor, if desired). I personally recommend a motor.
If you take some time, and select some good components, you can set yourself up with a FTA system that beats many cable company's offerings with the only cost to you being the equipment.
If you appreciate the channels available, it is a first time and once only cost for the system and setup, with no subscription fees.
RADAR
I thought your description was pretty straight forward and excellent, but I wanted to add my own "twist" to it. Hope you don't mind.
