Change service address for local sports
Towerosour
3
nashville, tn
Is it possible to "move" and change your service address to receive the local channels from another city? Or does the physical location of your receiver determine which local channels you get?
Welcome to Satelliteguys!
Check the satmaps link at the top of the page. There is one for Chicago. IIRC, you have to be within the pink line to have stable reception.
The service address DOES determine which local channels AND RSN(s) you get for you particular area.
But, since you specifically asked about local sports - were you meaning sports that are broadcast on local Chicago OTA stations, or on local RSN's?
If you are wanting sports on local Chicago OTA stations, as already pointed out, you are (WAY) too far away from the local Chicago channels spot beam. I can you they are just on fringe for me as well. ;)
But, if you were wanting only the Chicago RSN, which in this case would be Comcast Sports Chicago, you COULD actually get those, as all RSN's are carried on CONUS beams. But your problem is, when you changed to a Chicago address, since you would be switched to Chicago locals, you would NOT get ANY network prog (ABC, CBS, etc.) through the dish, since you cannot pick up the Chicago spot beam.
Makes sense???
The Other option would be to have a DirecTV receiver with an integrated OTA tuner or get a AM-21 tuner, then you could receive your local channels from the OTA Tuner module and still get the Chicago RSN's.
John
H24 Audio to Older Receiver
DirecTV weaker signal in Cayman Islands
