Is the green LED on the front panel an automatic HD indicator, or is it just a flag that can be set by the user?  I found in one of the channel edit programs where the LED can be set to turn on for a channel, but will it also detect an HD channel and turn on to indicate?
I wasn't able to receive any HD channels that I know of. Will Axbox find an HD channel in a regular blind search or does something have to be done to make it look for the HD channels? I noticed in advance scan that different modulation methods can be selected.
The Axbox came pre-programmed for some channels on 103W. The Pentagon channel worked, and the beaches both worked but none of the others.
I was still trying to learn how to use the Axbox when apparently the power supply failed. The LED is off on the AC adaptor so I assume it's the power supply. It's about a week old.
