I received an email earlier from a customer about our ESX521 Ku LNB and wanted to share it with the people here. I receive emails from customers all the time about our products, but I find it interesting when I get an email that actually compares two products, regardless of if it's comparing our older product with our newer product, or a competitors products to our products.
I have "X"ed out the customers name and username he uses in the forums for privacy reasons and because I have not yet received a reply back with permission to post it.
Your input as a user of our product is very important. Some of the improvements we make to our products are a direct result of customer inputs. If anyone wants to shoot me an email at anytime and about any of our products, please feel free to email me directly at rob@wsidigital.com.
More than likely, I will create a section on our site for customer testimonials whenever I can get a chance.
Remember, you guys are the reason we keep improving and pumping out new products. Thanks for your support of WS International satellite equipment.
Hello my name is XXXX XXXXXXX i own a traxis 3500 i use it for ku band only sd my set up is 3 dishes each locked on one sat then i add multi lnb's to each dish and i have 16ku linear lnb's in total now through out my 3 dishes
one dish is a 3 footer the other 2 are 1.2m im very good at tweaking in borderline transponders WEAK SIGNALS and have found that the best lnb i could buy and use was a brand called the spitfire lnb and it is a great lnb! i have only 2 spitfires and a couple of fortec a quad polar and some univeral some standard lnbs.
I just bought 5 of your ESX521 standard lnb from e bay i wanted to replace 4 older lnb's anyway i was SO IMPRESSED right away with your ESx521 because it realy does improve right off the bat the quailty numbers i was getting on the 4 older lnb example on 79w telemundo 72% to 80% it seemed all the lnb i was replacing i noticed an increase by a lot.
But the most IMPORTANT THING EVER IS i use the spitfire on 2 other sats 72w and 103w and would never dare think of using anything elses because the spitfire did add 5% to my numbers and that made and broke see or not seeing transponders as long as i used the spitfire lnb i got enough to get picture on the weak ones i aimed at
but your ESX521 IMPRESSED ME SO MUCH! that i took off THE SPITIFRE TO SEE re aimed it tweaked it and YOU FOLKS BEAT YES BEAT BEAT BEAT! THE SPITFIRE!
ON MY 79W DISH 1.2m dish i then add a lnb for 72w and there is this one weak one as an example ill use its the dooms day religous dude on 72w 11890h 1666 symbol rate
when i used the spitfire lnb id get 64 65 66 quailty with your ESX521 i get 71% steady and today it jumped to 72% Also
in the moornings on 72w there is 3 spanish tp on 72w 12023h 12028 h12032h till around 10 am with the spitfire this was the only lnb i had that would be able to lock in these three tp
the 12023h sometimes was very borderline and went under the threshold and pixel bad to weak to see yesterday when i was installing your lnb's on the old lnbs i was replacing i wasnt going to use it on 72w but like i said i was so impressed with your lnb i tired it and guess what it played! i had higher numbers i was getting around 65% quailty with the spitfire needed 68% for picutre and your esx got me 71%! and picutre.
SHOW THIS E MAIL TO THE HEAD DUDE!
I XXXX XXXXXXX of lake worth florida will only use your new ESX521 lnb from now on!! it is the best fooken lnb tommorrow im going to replace the other spitfire i have at 103w there is a few that are still toughon that sat for me in the mornings id like to beef up and i bet your esx will do the trick!
once again wowser what a amazing lnb and again dont get me wrong the spitfire is also a great lnb buts its not as great as yours!
you folks have the best linear ku band lnb it should be rated not 2.0 rather .05 and the spitfire can be 1,0 but your is better which to me is very impressive and i dont know if there is even a ratting of low noise of 0.5 but if there is you folks deserve it!
take care XXXX XXXXXX aka XXXXXXXX XXXXXXXXXX and XXXX XXXXXX i call my self XXXXXXX and XXXX XXXXXX on 3 forums i read at and ps only un scrambled sutff no iks crap for me those dummies i was once a johnny depp but this is more fun to see live news feeds and helicopter chases lol and you never get a davey letter lol.
