Is there anyway to get SD channels on a HD reciever like Dish does? Thanks
All that shows up on the reciever are HD ones. How do I convert so I see SD channels?
Go into the menu and click setup, system setup, display, preferences, guide hd channels, and change it to show all channels.
Thanks, I tried what Raoul suggested and it worked! Thanks so much
I'll switch to the SD channel when the HD channel is showing stretch-o-vision (TBS HD is an example)If you did that, when you go to the guide, you'll now see both versions in the guide .
I'll from time to time do that when the weather gets real bad and if I need to I'll switch back to the SD version as that will last longer than the HD will.
1st channel in the guide is the HD version...2nd is SD
also the giant [HD] in the programming name is a giveaway too![]()
Not near as much as they used to. Yesterday for example, I went to watch "The Ringer" labeled in glorious HD on TBS. When I tuned to the channel it was in big shoulder mode. Ended up watching it on TBS SDThey don't stretch much content now do they? I know HGTV does.
