New HD GUI
dfecarter said:
I received the 0x57b version update at 4am yesterday...but no sign of you tube anywhere...where should I check for it?
It shows up as a choice when you do a keyword search. :)
This might make more sense.
I am REAL happy with this current CE, so much that I might not do Fridays, that would be a change for be as I have done all of them since it started.
Maybe I'll do it on the HR20-700 in the bedroom first.
Wow I love DirecTV but I am very upset!!!
With the new DirecTV guide on my TV screen I can see my shows but when I watch TV or recorded shows on my DVD player I get "Your TV or its cables are not HD!" I have a HDMI Cable & a Red,white, & yellow cables set up to connect my DVD player tothe HDDVR(HR24). I have never had any issues with my DVD player & HDDVR until the guide was downloaded two nights ago. I can still see TV on my DVD player but everytime I click play or try to watch TV a grey pop up comes up and Says the error message above but I can still see the TV behind the popup that will only go away if you pause the TV.
Besides that, when fast forwarding when you click play it keeps going and instant replay does not work so good.
Can anyone help on the DVD player part, i'm really upset
Can you try this with the HDMI cable only ?
ahhh I figured it out! soooooo happy!!!!
When the gray screen came on saying the message in bold above, I held the exit button like it said so my TV was no longer HD resolutions and it only became 480i but when I went to the menu screen and HDTV options and TV resolutions and moved it up to 480i and click info to confirm I could see the picture. Then I turned on 720p and the gray screen came up saying the message above in bold but I still clicked info(even tho it did not give me the option) and the gray pop up went away! :) Then I turned on 1080i and gray popup returned but I just hit info and the gray screen went away and thenI turned on 1080p and the gray screen popup came again and I just hit info and it went away! :)
So it must be a glitch because I can see the HD Guide and the TV sceen.
This was gray popup I was getting https://twitter.com/#!/EricSturrock/status/150063431909773313/photo/1
Can I ask why have an HD DVR if you don't have an HDTV?
MANY times D* will give you a HD DVR instead of the SD one as they are working towards everyone having HD also there are areas that are no longer running MPEG2 and are required to have a HD version as they run MPEG4.
most new local markets added are only in MPEG4 so a HD reciever is required
or someone like me that has 2 R22's that the only way HD can be turned on them is if there is a "legit" HD receiver on the account. So I got a H23 and put it on my 32" SDTV (as both my HDTV's have R22's on them)
LOS Issue
waiver for out of market locals.
