211 vs 211k
dave10a
10
USA
What is the difference software and hardware between the 211 and 211k other than color. I have a 211 that is working on East Arc with my 222k. I would like to know if the 211 will work with the "tailgater" dish and will it work with legacy dish 500 twin with a SW21 switch. I want to use it while traveling on my motor home and am considering alternatives...
as Bobby noted the 211k can be used with the tailgater
All receivers will work with Legacy equipment. I have a 211k with a D500 Legacy Twin and a separate dish for 129 combined with a SW21.
If you have a 500 Twin and only need 110 & 119 you dont need the SW21.
The smart card is probably built in. If you get any channels at all, like 101, it's cool. Otherwise you problem need a new card.
I have a 211 (not K) without a smart card. Do I need a smart card to activate it?
more then likely as the 211 has a embedded smart card (internal) but may not be the 3rd generation card that is needed......
call dish with the receiver number and they will tell you if it can be activated and if you need a new purple card...
A 211 will work with the tailgater just has to have the correct s/w. I forgot to look at the s/w for the one I saw work the other day. It pulls up the portable antenna screen and everything. If I see another one I will oat on here.
newer receivers have the card built in...but check system info screen and if the S# shows S19 as csmith said it should be ok
Thank for the info-- Looks like the only difference between a 211 and 211k is color the 211k being black and the 211 is silver. And both work with legacy equipment.
Dave
Hbo...Cinemax...Showtime
Newbie asking: How do I move TV2 to a different room with existing cable?
