DISH HOPPER SPEC SHEETS
I think I got it. Either way it will work in my house I'm just curious about customers who do not have internet. Will they be able to have the Hopper working in their homes?
Hmmm.
125 watts on the back panel of the Hopper and volt/amps on the Joey.
No operating or standby power consumption specifications listed for any of the devices.
And they call these Product Sheets.
Can anyone tell me if the built-in WiFi in the Hopper is dual-band (2.4/5.0 Ghz)?
you're talking about the Hopper Internet Connector which seems to have wifi listed... right?
The Hopper itself doesn't have wifi according to the spec sheets. All i see is ethernet on the Hopper spec sheets.
(Hopper Internet Connector used to be called the XIP MoCA Bridge in the information from last year.)
Looks to be they want everyone to switch to the Hopper and I don't blame them.
I don't see anything implying a joet functions as a bridge.
Now that you mention it, neither do I! It wasn't in these new PDFs as you pointed out, but I thought I remembered a wiring diagram in one of the photo dumps which of course I can't find right now. So... What will that Joey Ethernet port be good for? Nothing?
Not going to happen... ever.
Ouch, you cut me deep Scott. :( I guess I'll have to look into the Hopper. On that note, if you are using a tuner for the prime time feature, will we be able to use that same tuner and watch any of the 4 or 5 channels it is recording, or does that eliminate the use of that tuner while recording using the prime time feature?
I'd like to hope one can use ethernet instead of the MOCA for connection between hopper and joey.
Looking at the wiring diagrams, the setup seems pretty simple but I'm curious to know about setups that currently use a video switch. I'm using a 1000+ with the DPP44. If/When I upgrade to the hopper/joey system, will I still be using the DPP44 and if so, how will it work under the new setup?
You will still use a switch if you have one. :)
Certainly sounds like one heck of a system so these questions are not meant to sound negative!
No OTA tuner, correct? So obviously I could watch the subchannels directly on the TV, but not record them anymore.
If based on the 922 UI, could that mean no Manual Timer? (If I am correct the 922 does not have a manual timer)
If the Hopper dies, that means no TV in any Room?
You will be able to use a USB OTA Tuner sometime after the Hopper is released.
No manual timer but something they ARE working on.
And yes if the Hopper dies then you are without TV until you get a replacement. But thats the norm with any multi room DVR system
Seek & Record ™ to create custom DVR timers by channel, actor, keyword and more
This sounds a lot like "DISH Pass" with a new name.
NBA Free Preview
722K does not update program guide
