Thanks! Hopefully Dish will look into ways to make the timers cooperate with PTAT in order to prevent redundant tuner usage.
1. yes
2. I assume so
1. yes
2. I assume so
The redundancy is in setting a timer to record a prime time network show. Why do that when it is already being recorded..... If you don't have time to watch a program within 8 days you can easily save that program from the PTAT.
didn't someone already indicate that something like this would be added after launch?I don't want to have to remember to go back once a show has aired to tag the PTAT show to be saved after 8 days. That should happen automatically if there's a timer set for a show. If you couldn't set timers, it would be less of a convenience for a viewer and makes the entire system less streamlined. I for one don't always get back to a show within 8 days... heck sometimes 8 weeks.
Forgive me if this was already covered, but two issues are still unclear to me...
If the answer to #2 is yes, then I'd like to see a feature added to auto-copy the show from the PTAT buffer rather than consume another tuner. It seems silly to require someone to manually save those episodes from PTAT weekly. My family almost never has time to watch a show within 8 days of airing, and often we record 3 shows at once (722, plus OTA).
- If PTAT is disabled, is the 3rd tuner then available for standard timers to use?
- If PTAT is enabled and you also have a timer set to record a prime-time network show, will that timer still use another tuner?
-OD
#2 why would you when it's already going to be recorded?.![]()
Yes, this was brought a while ago. If the saving of PTAT shows is a manual intervention every week, then it will fail. The video demos showing the option to save a PTAT episode did not include an automatic option.
Because I won't get around to watching it within 8 days, so I'll be manually saving every week.
Why not automate the process somehow? Others here have mentioned having an auto-save feature for shows recorded via PTAT, but setting a timer makes a lot more sense because a)That's what customers are used to doing already, and b)You will still record the shows you want even if you disable PTAT.
Damn! Why can't this thing cook supper, put out the garbage, and mulch my garden!???
A recurring Save will be added but they weren't sure it would be available at launch.Oblong Desoto said:If the answer to #2 is yes, then I'd like to see a feature added to auto-copy the show from the PTAT buffer rather than consume another tuner. It seems silly to require someone to manually save those episodes from PTAT weekly. My family almost never has time to watch a show within 8 days of airing, and often we record 3 shows at once (722, plus OTA).
