SatelliteGuys when you go here it shows you are logged out.
When you log in you get the following error:
To fix the following I'd suggest going into .htaccess and remove # from the following:
This should fix the issue.
		Code:
	[COLOR=#3E3E3E]Invalid Redirect URL (http://satelliteguys.us/)[/COLOR]
		Code:
	# Comment the following line (add '#' at the beginning)# to disable mod_rewrite functions.
# Please note: you still need to disable the hack in
# the vBSEO control panel to stop url rewrites.
RewriteEngine On
# Some servers require the Rewritebase directive to be
# enabled (remove '#' at the beginning to activate)
# Please note: when enabled, you must include the path
# to your root vB folder (i.e. RewriteBase /forums/)
#RewriteBase /
[COLOR=#ff0000]#[/COLOR]RewriteCond %{HTTP_HOST} !^www\.yourdomain\.com
[COLOR=#ff0000]#[/COLOR]RewriteRule (.*) http://www.yourdomain.com/forums/$1 [L,R=301]
RewriteRule ^((urllist|sitemap_).*\.(xml|txt)(\.gz)?)$ vbseo_sitemap/vbseo_getsitemap.php?sitemap=$1 [L]
RewriteCond %{REQUEST_URI} !(admincp/|modcp/|cron|vbseo_sitemap|api\.php)
RewriteRule ^((archive/)?(.*\.php(/.*)?))$ vbseo.php [L,QSA]
RewriteCond %{REQUEST_FILENAME} !-f
RewriteCond %{REQUEST_FILENAME} !-d
RewriteCond %{REQUEST_FILENAME} !/(admincp|modcp|clientscript|cpstyles|images)/
RewriteRule ^(.+)$ vbseo.php [L,QSA]
