Fix vBSEO redirect URL
$885.00
IcEWoLF
12,807
11,992
Nevada
SatelliteGuys when you go here it shows you are logged out.
When you log in you get the following error:
Code:
[COLOR=#3E3E3E]Invalid Redirect URL (http://satelliteguys.us/)[/COLOR]
To fix the following I'd suggest going into .htaccess and remove # from the following:
Code:
# Comment the following line (add '#' at the beginning)# to disable mod_rewrite functions.
# Please note: you still need to disable the hack in
# the vBSEO control panel to stop url rewrites.
RewriteEngine On
# Some servers require the Rewritebase directive to be
# enabled (remove '#' at the beginning to activate)
# Please note: when enabled, you must include the path
# to your root vB folder (i.e. RewriteBase /forums/)
#RewriteBase /
[COLOR=#ff0000]#[/COLOR]RewriteCond %{HTTP_HOST} !^www\.yourdomain\.com
[COLOR=#ff0000]#[/COLOR]RewriteRule (.*) http://www.yourdomain.com/forums/$1 [L,R=301]
RewriteRule ^((urllist|sitemap_).*\.(xml|txt)(\.gz)?)$ vbseo_sitemap/vbseo_getsitemap.php?sitemap=$1 [L]
RewriteCond %{REQUEST_URI} !(admincp/|modcp/|cron|vbseo_sitemap|api\.php)
RewriteRule ^((archive/)?(.*\.php(/.*)?))$ vbseo.php [L,QSA]
RewriteCond %{REQUEST_FILENAME} !-f
RewriteCond %{REQUEST_FILENAME} !-d
RewriteCond %{REQUEST_FILENAME} !/(admincp|modcp|clientscript|cpstyles|images)/
RewriteRule ^(.+)$ vbseo.php [L,QSA]
I cannot get that error to duplicate on my end.
Here is how you can test, clear cookies, clear cache, go to satelliteguys.us without adding the "www" infront.
Then try to log in, when you log in it will redirect you to http://www.satelliteguys.us/login.php
Scroll down a little and you will see:
Code:
In proper setup when you type in satelliteguys.us it should automatically direct you to SatelliteGuys because the cookies are saved with www. not without www.
It's not a big deal, but it should be fixed...
insurance for installers
Forum is green?
