There is a low SR signal (1000) that when I went to TP LIST and manually entered the parameters to lock and add the channels to memory, it takes about 10-15 seconds to lock and then when you hit "OK" to search to add the channels to memory, there is a NO PROGRAM FOUND.  Since there is no signal meter on the scanning screen, I don't know if that TP loses lock between my "OK" keypress to its searching or if there is some other reason it won't find the four services in that signal to add to memory.   I do wait for the signal lock in the TP list screen before I hit "OK" to search just to make sure it's locked before I tell the MicroHD to scan it for the four services.  I went back and tried to manually enter the PID info for each service to add the four channels myself, and I still get a NO PROGRAM FOUND.  The system information stream is present and working so I would expect those four audio channels to be written to memory on a scan.
