So placed my order this morning at 10am for 1 hr34 and 3 c31's. I scheduled it for tomorrow at 8am, however at about noon the direct installer shows up at my house. I told him he was a day early but I didn't mind at all! So he was here for about a hour and half and now I'm up and running and so far so good. The hd menu is a nice change from my 722k. I'm going to be fiddling around with it tonight and I'm sure I will have many questions to come.
that sucks.
unislick said:Just had my install today. 2 DVRs (HR34, HR24) and 2 clients (C31s).
Still playing around with the equipment. A few questions (apologize if they are elementary):
1. What is the HD recording capacity for both the 34 and 24? Installer caused some confusion from what I read.
2. How do you specify what DVR you want to record on? Do you have to be at the HR24 to schedule the recording on that DVR or can one schedule a recording on the HR24 from a C31 or the HR34?
3. It appears a lot of video on demand conent expires after a couple months in the DVR. Is there anyway to not have the recording expire (I do already have the recordings set to expire when the disk is full)?
Appreciate the help. I am sure I will have many more questions.
BTW - anyone expecting an install with C31s and have old TVs (only RCA hookups, not component or HDMI), please ask your installer up front if he has the special RCA cable (10PINC31) that is not included in the C31 box to hook up your TV? My installer (his first C31 install) had no clue this cable was needed even after trying to hook up component video cables to my RCA inputs for some unknown reason . And he couldn't obtain any such cable till Monday because the warehouse is closed and no other installer knew what he was talking about so they didn't have any either. My install took nearly 7 hours with no new cable runs and I bet he fought acitivation issues for at least 2 hours of the install and another 2 hours learning how to enable the C31s. Other time was spent mounting new sat on new pole, grounding existing cable and swapping out all my newly added compression fittings because they weren't Directv fittings.
Sounds like Directv needs to train our local installers a little better on the C31s.
Any thoughts on above questions?
dishrich said:Unislick, (or anyone else that might know the answers to these questions)
I've got a client that was supposed to get (2) HR24's, & H25's installed next week. When he ordered all this, D* tried to talk him into the Genie, & presumably C31's I'm sure, in lieu of (some) H25's. Since D* said the order could be changed up to a day before the appointment, I'm considering having him switch 1 of the DVR's to a Genie, since he would get more tuners for recording; however, I DO have concerns about him having to get C31's instead of the H25's.
Since your setup appears to be very similar to my clients, have a couple questions for you:
- Can your C31's playback recorded shows from BOTH the HR34 AND HR24?
- Can the HR34 & HR24 playback from each other?
- On setting up recordings, can the C31 schedule records to EITHER DVR, or are they limited to ONLY the HR34?
- I'm assuming that when you schedule a recording from either DVR, it can ONLY be scheduled to itself, correct?
Thx for any info on this.
1. Yes. Although you can't schedule recordings across other DVRs or see other DVR scheduled recordings (which doesn't make sense...if the recorded list is an integrated, the scheduled list should be as well.
2. Yes. I am reading this question and your first as the same. If different, please elaborate.
3. C31s limited to HR34 AND the HR24 is limited to the HR24. Although, you can use the Directv app and specify which DVR you want to record to and record it through the app.
4. Yes. Which is a limitation IMO Directv needs to address ASAP especially since they are touting this whole home DVR solution so much.
Also, my equipment was changed right when the installer showed up...just took a phone call to Directv and for me to verify to swap two C31s for H25s....but that may have been more difficult if it was the other way around.
