Only if you keep the default ch60 output on TV2. CHange it to a low UHF channel and the gain of the TV2 signal will override the loss.
More splitters + noise = bad picture.
Nonetheless, diplexers are the correct tool to combine and separate signals such as these.
thxtech said:A trick I have used with sucess is to take a vhf/uhf amplifier to feed that antenna back into the reciever. Use one with adjustable gain and only turn it up as far as you need.
Both the distribution output and the remote frequencies are down in the OTA range so just about anything that isn't a diplexer should work.At Lowe's, there are several different types of splitters. Which ones should I use to add a remote antenna to where the TV is? is there a Ghz I should get?
