A friend told me that wireless joeys are coming.  No more coax or wifi adapters needed.  Can anyone confirm this?  Timing?
Can you install a new Joey over Ethernet alone? No MoCA?
Technically if you purchased your own you probably could. I think the initial software download requires a MoCA connection though. Could use a temporary tap on the Hopper line for that.
That is exactly what I was asking: can you install a Joey without MoCA at all? Getting to a tap, either temporarily or permanently, is not easy for my proposed setup which would kill the MoCA signal in the attic. That's in order to run an OTA antenna signal to the Hopper OTA dongle via a single coax.
You can't put a temporary tap on the hopper line right behind the hopper to download the joey?
