Hopper not hopping
ashutto20
1,255
85
United States
Just got dish installed in my house...but the last few nights some recordings starting on Sunday would be time to record and the channel...after hitting the red button...will say lost signal and not record...
Red reset numerous amounts of time will eventually get it to work...the hopper upstairs. ..same channel comes in just fine no signal loss
Anyone else had this and why is it doing this??? New software glitch???
Press YELLOW - BLUE - 3 - Select "Send Status" - Select "Connection" - wait - select "Check Signal." What are you getting on each of the sats and tuners?
70-80 for 110 and 119 and for 129 48-55 range...
Ill check for sure when I get home but last night those were my #s
As of now...
119
14-1...79. 14-2...78
15-1 and 2...86
16-1...84 16-2...85
21-1 and 2...82
110
14-1 and 2...76
15-1...71. 15-2 ...69
16-1 and 2 ...76
21-1...73. 21-2...72
129
19-1 and 2...46
20-1 and 2...59
29-1 and 2...66
30-1...60. 30-2...59
Is that good or bad??? Haha
As of now...
119
15-1 and 2...86
16-1...84 16-2...85
21-1 and 2...82
110
14-1 and 2...76
16-1 and 2 ...76
129
19-1 and 2...46
20-1 and 2...59
29-1 and 2...66
Your numbers are good for tuners 1 & 2. Is column 3 blank?
Sent from my iPhone 4S using Forum Runner
Yes it is blank...is that bad???
I believe they are 0
Yah, means your third tuner isn't working. Either a problem with the cabling between the Hopper and the node, or a missing/broken node, or possibly a connection issue between the dish and the node. Do you have one Hopper?
Just got it installed last thursday...have 2 hoppers...turned it on tonight and got a 11-12-11 code??? Tells me if problem continues to push red reset
First time having these issues...have had hopper since day 1
Can you run that test on the other Hopper and post?
119
14- 1 2 3 ...78
15- 1 2 3 ...86
16 - 1 2 3 ...86
21 - 1...84. 2...83. 3 ...84
110
14... 1 2 3 ...77
15 1...71. 2...70. 3...71
16...1 2 3...77
21...1 2 ...73. 3 ..72
129
19. 1. 2...46. 3...45
20. 1. 3...59. 2...58
29. 1...66. 2. 3. ...65
30. 1 2. 3...59
Sorry hope you can read it...so I see the problem is with the hopper downstairs...no #s on the 3rd column
I guess I need to get a tech out asap huh???
Yeah. Do you have access to your node by any chance? Are there three feeds going into the top of the node (the side with 3 ports?)
Yes 3 feeds going in...
I tried to attach a pic but it says application crashed haha...ok well there are 2 pics oops haha
Leaning toward bad node or bad cable/connection between Hopper and node. In rare cases bad receiver. Also, that unused CLIENT port needs a 75-ohm terminator.
I hope its not the receiver...0 problems w it until the new install
What is the 75 ohm terminator used for???
Will this be an easy fix by the tech???
75 ohm terminator makes sure the MoCA signal doesn't leak from the unterminated port as well as keeping outside interference out of the system.
I don't think the tech will have too many problems fixing your issues, if they're competent.
So of course the 3rd column is working when the installer is here haha
Lets hope this problem does not come up again haha
He said it could be that 3rd tuner
Update: So there was signal at first but after a few things the tech did it came up 0 for the third tuner...so looks like its the hopper
Cant switch them out because I dont have an ehd and I have 67% recordings on thid receiver
Where is the best and cheapest haha place to get an ehd???
Please help me point and setup my Dish
New owner &member with a question.
