OTHER X2 Premium HD PVR Satellite Receiver
how does that work ?
used database back up. ended up with 1 file with .ssu on it. is that it ?
thanks
database is for channel list backup with transponders.. will be about 449.kb
application will be the firmware backup and it will be about 3585kb
so how to get firmware backup on a usb stick ?
thanks
Menu ---> Setup ---> Upgrade and backup --> Upgrade by USB
Make sure it says Application 1 ---> Scroll down below where it says USB0(ROOT)
Then scroll to the right ---> select your backup ----> press OK on remote
then it prompts "Are you sure to upgrade this file?" ---> click OK on remote
Wait til it reboots.
Once you are back on, check firmware for proper upgrade.
setup ---> system information.
thanks
but it sounds like that would be the way to up grade the sw on the x2 box.
i want the firmware off the box to the usb stick.
thanks
thanks
thanks
haha damn I read it wrong.. well at least now you know how to load it from USB :)
Here is the X2 to USB
Setup ---> upgrade and backup
Scroll down to Backup to USB
make sure you select Application 1 to backup firmware. (user database for channel list and transponders list)
Scroll down to USB0(ROOT)
Move to the right and click on Add New Files.
Name your backup and save it.
click on the saved backup and it will prompt "Are you sure you want to backup to this file?"
click OK
Done.
click OK
Done.
still i..
thanks
Thanks to pro96 for sharing:up , I loaded and tested April 9. Looks good so far. Still the sat list is all scrambled. This is a USA sat list from 45W to 139W which is going to be included into all X2 USA future releases. You can load the April 9 and them this USA sat list and everything should work great,
still i..
thanks
yup just make sure its at least 3mb and like XTGOLD said, you can also do a full dump which will be about 8mb. I've done both when my (2) x2 where purchased right before I upgraded any fw.
click OK
Done.
When this is done, does it copies everything into the USB stick, such as the Hardware version, Software version, Date of the update was made, etc, or just a portion.
My receiver should be arriving this coming Monday, and I want to be a little bit informed of what to do.
Thanks.
Thanks.
If you do a full dump yeap.. also do application 1 dump for your backup purposes.
Press and holt your control key and then hot refresh on that page as it sounds like you have the old closed page stuck in cache.
There is an issue with our SatelliteGuys Downloads Software which we are actively working on. We hope to have downloads (and uploads) restored as soon as possible! Thanks for your understanding!
OTHER Default Syrian Drama 97w 11898 22000 V not working?
OTHER Diseqc 1.2 motor on a budget
