Direct tv HD DVR Gennie 34 Series Manager Setup ?
sportman13
352
4
Dose anyone know the dvrhd34 set options for first run and with NO Repeats on the Direct tv dvrhd34 in the series manager the order it is display on the Reciver I want know Repeats ?
Hit info on what you have set to record (must show the "R" on the top of the screen) and select "first run" "repeat" or "both"
Hutch1814 I have it on default All Episodis on Direct tv HD DVR Gennie 34 Series Manager Setup do I have the wrong set up for No reapeats if it is wrong what is the right set please
"First run" is what you want, follow my previous post and it'll get you fixed up
Hutch1814 could you please show me a screenshot of the set up for No reapeats in default for the Direct tv dvrhd34 please
Sportman1,
Menu-Recordings-Manage Recordings-Record Defaults
Then if you move the cursor over "Episode Type" and hit Select, you'll have 3 options pop up.
First Run
Repeats and
Both
Select the one you want
Sportman1,
First Run
Repeats and
Both
Thanks Jimbo, I've been drinking and cooking since noon and couldn't even tell you how to do that, if it wasn't for autocorrect I'd be in trouble
Jimbo I am a disabled person here is what I have for default dvrhd34 genie set options for first run All episodes I do not see options for Repeats and
Both or No Repeats could you show me a screenshot of the set up for first run and No Repeats for the dvrhd34 genie please
Hutch1814
sorry to bother you
for the settings I put
Episode Type: Choose First Run
Keep at Most: All episodes
Keep Until Delete
Directv dvrhd34 genie in theses settings keeps recording the repeats is their a fix do I do a reset ?
Sorry, I don't have a way to take a picture and put it on the site.
When you get to the point where you see Record Defaults, the 1st one up says "Episode Type" highlight it and hit the "Select button" azt that point it will say on the screen
First Run, Repeats and Both.
Highlight First Run and hit Select.
Then back out of of the settings section.
Also, even though you set the Recording Defaults for First Run, I would also make sure that when you set up your Recordings that that particular Recording is also set for First Run as well.
Jimbo for the settings I put
Keep Until Delete
ejb1980 I am a disabled person not very technical with attachment
Here is my set up for direct t dvrhd34 Genie
Keep Until Delete
Just click on the attachment with your mouse... it will get bigger.
I don't know what else to tell you. Let me try this:
The next post will have another picture, from the menu that others have written how to access, and I will again:
Press "Menu" on your remote
Press the down arrow until "Recordings" is blue, press "select"
Press the right arrow until the orange "Manage Records" menu is selected, press "select"
Select "Record Defaults" and this is what you SHOULD see. If you see "First Run" at the top, you're all set.
HOWEVER
I bet if you didn't have it set that way before now, you will have to update each program that you made previously on its own. I will also mention this: despite the proper settings being selected, it will often record old episodes, seemingly at random. I don't know why. Mine has been set to "First run" since the first day I got my Genie, also HR34. The picture I posted before was me showing an specific programs settings, not the general default. Sorry if the other picture confused you.
yup. Any old settings are saved on existing series recordings so you will need to either erase all existing series and redo or change each one.
If there is no "first air date" it will record it as a precaution. I have one episode of Alaska State Troopers that records EVERY time it shows up in the guide because the first run date is dropped (it just says 2013). Also have a local wrestling show that is on twice a weekend and it records both because there is no air date.
It used to happen on my HR24, too, so I am going to guess that it's not a specific DVR issue, and probably not even an exclusively Directv issue, but we shall wait for Iceberg's reply.
I have the DIRECTV: Genie (HR34) Iceberg's reply.dose he have this DIRECTV: Genie (HR34) to ?
Directv ,any free promos like Dishnetwork this summer?
Directv or dish?
