Dish recommendations
maulder
2
United States
My dish was damaged in a storm and I need a new one. All I know is that it was a slimline dish. I would like to find a used one on ebay, but I'm not sure which dish will work with my system. I have a 1 HR24 DVR and 2 HD receivers. Can someone give me a recommendation? Thanks!
:welcome to Satelliteguys maulder!
All Slimline dishes are the same. The lnb may be different. How many cables come from the dish? If one, then you have a swm type lnb. Hold the dash key down and you will get an osd telling you such if you have a swm setup. Which ever type, swm or non swm, replace it with the same type.
I assume it is not a swm. It had 4 cables coming from a single lmb. Which type is better?
Definitely not a swm lnb, although it's possible you have a swm8 switch somewhere. How many cables to each dvr? If two, then there is no swm8 switch. Neither is necessarily better than the other. It depend upon your equipment.
Genie install
Well, I'm Back!
