Anything less than simultaneous multiple satellite view and HD will be unacceptable.
I agree with this in general. But you can do pretty well w/72.7 only. All you'll be missing are your locals.
If you go full timing, you are going to want a Trav'ler automatic roof dish or get good with setting up a ground tripod. Anything less than simultaneous multiple satellite view and HD will be unacceptable.
Hey, if Dish can survive on 9% margin, then retailers can live with 15% margin.![]()
Just received the Pathway X2 today and so far have mixed reviews. I'm in Sarasota FL currently and have a TRAVLER mounted on the roof of my RV but parked under heavy tree cover so no signal on the roof.
Tried to set it up for 2 receivers, on the setup you select either 1 or 2 receivers, if you choose one receiver you can choose whether you want to use the Eastern or Western ark; if you choose two receivers you don't get to choose (the selections are blocked out). When I chose 2 receivers and started the scan it found the eastern ark pretty quickly BUT no locals. Called DISH, they confirmed that locals are only available on the 119 & 129 satellites.
So I called Winegard to see how, if possible, to force the antenna to use the western ark when selecting 2 receivers, they told me NO, when in the 2 receiver mode you have no control.
So I'm currently configured in the 1 receiver mode and locked on the western ark and only able to use one receiver/TV.
I hope Winegard figures a way to allow the user to force the Pathway to use a specific set of satellites, in the meantime I'm stuck with what I have!!!
Is this still the case? I would be on the western arc myself and kind of want to get one of these for my tailgating setup this fall but won't if we can't do 2 tv's with it.
