h23 and h25 compatability
royc349
5
brownville
i'm trying to add an h25 to my current setup, i have a slimline 5 lnb with a multi switch, i have attached a b-band convertor to it and it still gives me a 755 error, my h23 is working fine on all ports of the switch, can i get answer on whats wrong?
roy,
also,No BBC's with a SWM set up.
So if you move to the SWM as you will have to to use that recvr, do away with the BBC at that time.
the H23 has the BBC built in. no BBC needed even on a non swm setup
Correct ...
However, it sounded like he originally wanted to use the H25, if he goes that route, he'll need the SWM set up and no bbcs.
Looks like the recvrs he's dealing with would not need bbcs regardless.
hi satellite guys, i have a genie hr44 and 3 c41 clients, the clients worked for a couple days and now they have shut down. how do i link them once again?
the ask me to try again but i cant get to the screen to out in the new numbers
What do you mean by "shut down", what error message do you get?
the clients just said "try again" , there was no error message. it appears the dog had chewed the wire going to the genie!!
but the genie was still working fine. after replacing the wire the clients came right up.
Tailgateing Question
HBO GO Question
