Well, another day spent sitting in the sun.
First up for the day, I moved the motor to zero using the MicroHD menu. Then I put this rather large square against the side of the motor and the other edge up against the plate that the dish is bolted to.
It was definitely NOT square with the motor. I loosened the dish a bit and gently bumped it back so that it was absolutely 100% square with the motor.
There is zero doubt in my mind about it being square with the motor now. However the photo I took doesn’t really show that, I just held it up after the fact to give a view of how I did it, after the fact.
I went back inside (Sheesh! I wish this fancy pants new meter would move USALS HH motors !) and I moved the dish to 95w/G3C.
I went outside and tweaked the signal by adjusting the dish up and down and adjusting it’s azimuth on the pole, the entire thing as a whole, not the dish alone. I changed the motor azimuth.
I got what looked like a great signal on 95, according to my meter.
So I moved the dish to 125. No signal.
I adjusted the elevation of the dish itself and did not touch the motor. I got signal now. Back in the house, scanned in EVERYTHING on 125, like a boss.
Moved the dish to 72. Nothing. Nothing at all.
Moved it over to 87. Barely. Some stuff comes in but not everything.
Back to 95 and another episode of lefty-righty-upsy-downsy. Back to 125 and now SOME stuff comes in but not everything.
Still nothing on the east side.
I have long since misplaced the manual for my motor but fortunately for me, I took photos of it and uploaded it here a few years ago when I bought it.
After reviewing the missing manual, I have learned one thing and assumed another.
First off, my dish is a home made Frankendish so there are no “proper settings” for it.
I have been mistakenly using the wrong terms to describe my antics. I have been twiddling ENDLESSLY with the
declination of the dish, for which there are NO markings at all on it.
The inclination of the motor however, I have come to ASSUME, is probably off a bit.
I’m at 29.58 latitude but the manual only has settings for absolutes, 28, 29, 30, etc.. . I’m just a little over the middle.
I have the motor elevation set at 61, according to the manual and rounding DOWN to 29 latitude.
At this setting I have had nothing but misery so now I have decided to try and change the motor inclination from 61 to between 60 and 61, which should jive with me being between 29 and 30 latitude.
Then I’m going back to 95 and try again.
I sure wish there was a handheld, battery powered USALS controller you could bring outside to the dish.
Someone PLEASE make one????????? THANKS!
