Dee_Ann
Just a thought from a lurker on this thread. Have you watched your meter as you tighten everything? You might be able to adjust your tightening pattern to keep everything very close to your peak settings.
I have a bit of a Mickey Mouse set up on my Ku band and had a somewhat similar situation. But, I discovered that by tightening on one side It pulled back into alignment. The other thing is, that if you are warping it, you are probably over tightening it. It needs to be tight, but not over tight.
Hope it helps.
Format 2.4
Satellite1 -72.0,AMC6
Version 10
Date 06/17/2014
Time 16:50:48
Model TURBO S2
Location
Technician DEE.ANN
Notes
LNB Model Std N.Am Ku 10.75
FieldGuide North American V 2.19
Software 1.34
Serial *******
Level dBuV
Region SE Continental US
Switch None
Meter TurboS2
Orbit Tran Frequency Level C/N IRD Eb/No Es/No Lock Polar Id DnLink FreqError Mod Code Baud LnbV LnbI ReqLim Result Band Manual AvgLim
-72.0 Tr B2S1 1033.600 70.3 15.4 100 14.9 16.7 LOCK V . 11783.600 0.022 Turbo Q-2/3 2522 13.3 Under . . 0 Tr B2S1 .
-72.0 Tr I3A1 1081.008 72.5 12.4 93 11.9 13.7 LOCK V ID 11831.008 0.012 Turbo Q-3/4 14737 13.3 Under . . 0 Tr I3A1 .
-72.0 Tr 20 1303.064 67.0 10.6 82 10.1 11.9 LOCK V . 12053.064 -0.075 Dvb-S 5/6 6890 13.3 Under . . 0 Tr 20 .
Left(even) Right(odd)
Min Max Min Max Measure
Tr -1 0.0 Tr -1 0.0 Tr 20 67.0 Tr 3 72.5 Level
Tr -1 0.0 Tr -1 0.0 Tr 20 10.6 Tr 2 15.4 C/N
Tr -1 0.0 Tr -1 0.0 Tr 20 82.0 Tr 2 100.0 IRD
Tr -1 0.0 Tr -1 0.0 Tr 20 10.1 Tr 2 14.9 Eb/No
Tr -1 0.0 Tr -1 0.0 Tr 20 11.9 Tr 2 16.7 Es/No
Transponders Found: 3
2 3 20
Left Co-Polar: Tr -1 Tr -1 0.0 dB
Right Co-Polar: Tr 3 Tr 20 5.5 dB
Cross Polar: Tr -1 Tr -1 0.0 dB
Format 2.4
Satellite1 -87.0,SES2
Version 10
Date 06/17/2014
Time 16:50:48
Model TURBO S2
Location
Technician DEE.ANN
Notes
Software 1.34
Serial *******
Level dBuV
Switch None
Meter TurboS2
-87.0 Tr 2 986.788 70.7 13.5 96 13.0 14.8 LOCK V . 11736.788 -0.040 Dvb-S 2/3 8333 13.2 Under . . 0 Tr 2 .
-87.0 Tr B2N1 1029.812 69.1 13.5 96 13.0 14.8 LOCK V . 11779.812 -0.063 Dvb-S 1/2 5000 13.3 Under . . 0 Tr B2N1 .
-87.0 Tr K3B1 994.760 65.8 11.6 88 11.1 12.9 LOCK H . 11744.760 0.264 Dvb-S 3/4 3979 17.9 290 . . 0 Tr K3B1 .
-87.0 Tr I3A1 1061.392 67.8 0.0 . . . Unlock H . 11811.392 0.000 DvbS2 8-3/5 11150 17.9 290 . . 0 Tr I3A1 .
-87.0 Tr C4C1 1051.268 69.4 16.1 100 15.6 17.4 LOCK H . 11801.268 0.295 Dvb-S 7/8 2687 17.9 290 . . 0 Tr C4C1 .
-87.0 Tr C4G1 1138.584 74.3 16.3 100 15.8 17.6 LOCK V . 11888.584 -0.093 Dvb-S 5/6 10000 13.3 Under . . 0 Tr C4G1 .
-87.0 Tr C4F1 1258.688 63.4 13.4 96 12.9 14.7 LOCK H . 12008.688 0.279 Dvb-S 3/4 2170 17.9 290 . . 0 Tr C4F1 .
-87.0 Tr C4H1 1294.332 66.2 0.0 . . . Unlock V . 12044.332 0.000 DvbS2 Auto 3223 13.2 Under . . 0 Tr C4H1 .
-87.0 Tr C4I1 1299.832 62.3 11.9 90 11.4 13.2 LOCK V . 12049.832 -0.084 DvbS2 8-2/3 4800 13.2 Under . . 0 Tr C4I1 .
-87.0 Tr 5 1044.980 67.7 12.6 94 12.1 13.9 LOCK V . 11794.980 -0.081 Dvb-S 1/2 5000 13.2 Under . . 0 Tr 5 .
-87.0 Tr 5 1078.264 74.6 14.9 99 14.4 16.2 LOCK V . 11828.264 -0.069 Dvb-S 5/6 10000 13.3 Under . . 0 Tr 5 .
-87.0 Tr 14 1210.064 71.4 11.2 86 10.7 12.5 LOCK H ID 11960.064 0.309 Dvb-S 3/4 29270 18.0 290 . . 0 Tr 14 .
Tr 4 63.4 Tr 14 71.4 Tr 4 62.3 Tr 5 74.6 Level
Tr 14 11.2 Tr 4 16.1 Tr 4 11.9 Tr 4 16.3 C/N
Tr 14 86.0 Tr 4 100.0 Tr 4 90.0 Tr 4 100.0 IRD
Tr 14 10.7 Tr 4 15.6 Tr 4 11.4 Tr 4 15.8 Eb/No
Tr 14 12.5 Tr 4 17.4 Tr 4 13.2 Tr 4 17.6 Es/No
Transponders Found: 10
2 2 3 4 4 4 4 5
5 14
Left Co-Polar: Tr 4 Tr 14 8.0 dB
Right Co-Polar: Tr 4 Tr 4 12.0 dB
Cross Polar: Tr 4 Tr 5 11.2 dB
Format 2.4
Satellite1 -95.0,G3C
Version 10
Date 06/17/2014
Time 16:50:48
Model TURBO S2
Location
Technician DEE.ANN
Notes
Software 1.34
Serial *******
Level dBuV
Switch None
Meter TurboS2
-95.0 Tr 1 970.080 74.7 13.1 95 12.1 13.9 LOCK H ID 11720.080 0.294 DSS 2/3 20000 17.9 285 . . 0 Tr 1 .
-95.0 Tr B2E1 1098.752 72.1 10.9 84 10.4 12.2 LOCK V . 11848.752 -0.022 Dvb-S 2/3 9000 13.2 Under . . 0 Tr B2E1 .
-95.0 Tr 4 1030.080 75.9 13.5 96 13.0 14.8 LOCK H . 11780.080 0.293 Dvb-S 3/4 20759 18.0 290 . . 0 Tr 4 .
-95.0 Tr 6 1130.036 70.6 11.3 86 10.8 12.6 LOCK V . 11880.036 -0.055 Dvb-S 2/3 5000 13.2 Under . . 0 Tr 6 .
-95.0 Tr 7 1090.072 75.0 12.8 95 11.8 13.6 LOCK H . 11840.072 0.296 DSS 2/3 20000 18.0 290 . . 0 Tr 7 .
-95.0 Tr 10 1150.072 74.9 12.8 95 11.8 13.6 LOCK H . 11900.072 0.294 DSS 2/3 20000 17.9 290 . . 0 Tr 10 .
-95.0 Tr 12 1180.068 74.3 13.3 96 12.3 14.1 LOCK H . 11930.068 0.296 DSS 2/3 20000 18.0 290 . . 0 Tr 12 .
-95.0 Tr 15 1240.064 72.9 13.1 95 12.1 13.9 LOCK H . 11990.064 0.296 DSS 2/3 20000 18.0 290 . . 0 Tr 15 .
-95.0 Tr 18 1300.060 73.4 14.0 97 13.5 15.3 LOCK H . 12050.060 0.298 Dvb-S 3/4 20000 18.0 290 . . 0 Tr 18 .
-95.0 Tr 22 1390.056 73.1 12.8 95 11.8 13.6 LOCK H . 12140.056 0.296 DSS 2/3 20000 17.9 285 . . 0 Tr 22 .
Tr 15 72.9 Tr 4 75.9 Tr 6 70.6 Tr 2 72.1 Level
Tr 7 12.8 Tr 18 14.0 Tr 2 10.9 Tr 6 11.3 C/N
Tr 1 95.0 Tr 18 97.0 Tr 2 84.0 Tr 6 86.0 IRD
Tr 7 11.8 Tr 18 13.5 Tr 2 10.4 Tr 6 10.8 Eb/No
Tr 7 13.6 Tr 18 15.3 Tr 2 12.2 Tr 6 12.6 Es/No
1 2 4 6 7 10 12 15
18 22
Left Co-Polar: Tr 12 Tr 15 1.4 dB
Right Co-Polar: Tr 2 Tr 6 1.5 dB
Cross Polar: Tr 6 Tr 7 4.4 dB
Format 2.4
Satellite1 -97.0,G-19
Version 10
Date 06/17/2014
Time 16:50:48
Model TURBO S2
Location
Technician DEE.ANN
Notes
Software 1.34
Serial *******
Level dBuV
Switch None
Meter TurboS2
-97.0 Tr 1 956.400 66.4 7.1 56 6.6 8.4 LOCK V . 11706.400 -0.028 Dvb-S 1/2 7161 13.2 Under . . 0 Tr 1 .
-97.0 Tr A4B1 1433.564 72.5 12.9 96 12.4 14.2 LOCK H . 12183.564 0.295 Dvb-S 3/4 21991 18.0 290 . . 0 Tr A4B1 .
-97.0 Tr 5 1086.072 77.1 11.6 88 11.1 12.9 LOCK V ID 11836.072 -0.081 Dvb-S 3/4 20765 13.2 Under . . 0 Tr 5 .
-97.0 Tr 6 1092.500 75.5 13.1 95 12.6 14.4 LOCK H . 11842.500 0.376 Dvb-S 3/4 22000 17.9 290 . . 0 Tr 6 .
-97.0 Tr 7 1117.068 76.7 13.8 97 13.3 15.1 LOCK V . 11867.068 -0.079 Dvb-S 3/4 22000 13.2 Under . . 0 Tr 7 .
-97.0 Tr 9 1148.072 76.3 13.0 95 12.5 14.3 LOCK V . 11898.072 -0.081 Dvb-S 3/4 22000 13.3 Under . . 0 Tr 9 .
-97.0 Tr 11 1179.064 75.9 14.2 97 13.7 15.5 LOCK V . 11929.064 -0.079 Dvb-S 3/4 22000 13.3 Under . . 0 Tr 11 .
-97.0 Tr 12 1185.500 75.2 13.5 96 13.0 14.8 LOCK H . 11935.500 0.370 Dvb-S 3/4 20000 18.0 290 . . 0 Tr 12 .
-97.0 Tr 13 1210.076 76.0 12.7 95 12.2 14.0 LOCK V . 11960.076 -0.093 Dvb-S 3/4 22000 13.3 Under . . 0 Tr 13 .
-97.0 Tr 14 1216.500 74.2 13.9 97 13.4 15.2 LOCK H . 11966.500 0.370 Dvb-S 3/4 22000 17.9 290 . . 0 Tr 14 .
-97.0 Tr 17 1272.064 75.8 13.5 96 13.0 14.8 LOCK V . 12022.064 -0.083 Dvb-S 3/4 22000 13.3 Under . . 0 Tr 17 .
-97.0 Tr 18 1278.040 74.4 10.9 84 10.4 12.2 LOCK H . 12028.040 0.326 Dvb-S 3/4 22000 18.0 290 . . 0 Tr 18 .
-97.0 Tr 19 1303.060 75.5 11.1 85 10.6 12.4 LOCK V . 12053.060 -0.082 Dvb-S 3/4 22000 13.3 Under . . 0 Tr 19 .
-97.0 Tr 20 1309.500 74.1 14.2 97 13.7 15.5 LOCK H . 12059.500 0.365 Dvb-S 3/4 22000 18.0 290 . . 0 Tr 20 .
-97.0 Tr 21 1334.056 75.7 13.2 95 12.7 14.5 LOCK V . 12084.056 -0.078 Dvb-S 3/4 22000 13.3 Under . . 0 Tr 21 .
-97.0 Tr 22 1340.524 73.9 14.4 98 13.9 15.7 LOCK H . 12090.524 0.343 Dvb-S 3/4 20000 17.9 290 . . 0 Tr 22 .
-97.0 Tr 22 1396.056 75.8 12.1 91 11.6 13.4 LOCK V . 12146.056 -0.081 Dvb-S 3/4 22000 13.3 Under . . 0 Tr 22 .
-97.0 Tr 23 1365.056 75.1 11.6 88 11.1 12.9 LOCK V . 12115.056 -0.081 Dvb-S 3/4 22425 13.2 Under . . 0 Tr 23 .
-97.0 Tr 24 1371.500 74.0 14.6 98 14.1 15.9 LOCK H . 12121.500 0.364 Dvb-S 3/4 20000 17.9 290 . . 0 Tr 24 .
-97.0 Tr 26 1402.500 73.6 14.1 97 13.6 15.4 LOCK H . 12152.500 0.364 Dvb-S 3/4 20000 17.9 290 . . 0 Tr 26 .
-97.0 Tr 27 1427.052 73.8 11.4 87 10.9 12.7 LOCK V . 12177.052 -0.080 Dvb-S 3/4 23000 13.3 Under . . 0 Tr 27 .
Tr 4 72.5 Tr 6 75.5 Tr 1 66.4 Tr 5 77.1 Level
Tr 18 10.9 Tr 24 14.6 Tr 1 7.1 Tr 11 14.2 C/N
Tr 18 84.0 Tr 22 98.0 Tr 1 56.0 Tr 7 97.0 IRD
Tr 18 10.4 Tr 24 14.1 Tr 1 6.6 Tr 11 13.7 Eb/No
Tr 18 12.2 Tr 24 15.9 Tr 1 8.4 Tr 11 15.5 Es/No
Transponders Found: 21
1 4 5 6 7 9 11 12
13 14 17 18 19 20 21 22
22 23 24 26 27
Left Co-Polar: Tr 4 Tr 6 3.0 dB
Right Co-Polar: Tr 1 Tr 5 10.7 dB
Cross Polar: Tr 1 Tr 4 6.1 dB
Format 2.4
Satellite1 -103.0,AMC1
Version 10
Date 06/17/2014
Time 16:50:48
Model TURBO S2
Location
Technician DEE.ANN
Notes
Software 1.34
Serial *******
Level dBuV
Switch None
Meter TurboS2
-103.0 Tr G1B1 1063.900 63.5 11.0 85 10.5 12.3 LOCK V . 11813.900 -0.119 Dvb-S 3/4 2170 13.2 Under . . 0 Tr G1B1 .
-103.0 Tr B2E1 1067.976 60.7 10.3 80 9.8 11.6 LOCK V . 11817.976 -0.094 Dvb-S 2/3 1481 13.2 Under . . 0 Tr B2E1 .
-103.0 Tr K3F1 1327.084 63.6 8.0 65 7.5 9.3 LOCK H . 12077.084 0.268 Dvb-S 5/6 4232 17.9 285 . . 0 Tr K3F1 .
-103.0 Tr A4A1 969.276 57.9 10.5 82 10.0 11.8 LOCK H . 11719.276 0.346 Dvb-S 3/4 1085 17.9 290 . . 0 Tr A4A1 .
-103.0 Tr A4B1 1010.032 71.1 12.1 91 11.6 13.4 LOCK H . 11760.032 0.353 DvbS2 8-5/6 30000 17.9 290 . . 0 Tr A4B1 .
-103.0 Tr A4C1 1090.032 70.5 0.0 . . . Unlock H . 11840.032 0.000 DvbS2 Auto 30000 17.9 290 . . 0 Tr A4C1 .
-103.0 Tr 12 1192.060 75.5 14.4 98 13.9 15.7 LOCK V . 11942.060 -0.086 Dvb-S 3/4 20000 13.2 Under . . 0 Tr 12 .
-103.0 Tr 22 1394.500 76.2 14.6 98 14.1 15.9 LOCK V . 12144.500 -0.032 Dvb-S 3/4 20000 13.3 Under . . 0 Tr 22 .
-103.0 Tr 24 1430.048 76.2 12.1 91 11.6 13.4 LOCK V ID 12180.048 -0.085 Dvb-S 3/4 24999 13.3 Under . . 0 Tr 24 .
Tr 4 57.9 Tr 4 71.1 Tr 2 60.7 Tr 22 76.2 Level
Tr 3 8.0 Tr 4 12.1 Tr 2 10.3 Tr 22 14.6 C/N
Tr 3 65.0 Tr 4 91.0 Tr 2 80.0 Tr 12 98.0 IRD
Tr 3 7.5 Tr 4 11.6 Tr 2 9.8 Tr 22 14.1 Eb/No
Tr 3 9.3 Tr 4 13.4 Tr 2 11.6 Tr 22 15.9 Es/No
Transponders Found: 8
1 2 3 4 4 12 22 24
Left Co-Polar: Tr 4 Tr 4 13.2 dB
Right Co-Polar: Tr 2 Tr 12 14.8 dB
Cross Polar: Tr 2 Tr 4 10.4 dB
Format 2.4
Satellite1 -123.0,G18
Version 10
Date 06/17/2014
Time 16:50:48
Model TURBO S2
Location
Technician DEE.ANN
Notes
Software 1.34
Serial *******
Level dBuV
Switch None
Meter TurboS2
-123.0 Tr G1A1 1021.700 64.6 9.5 76 9.0 10.8 LOCK V . 11771.700 0.070 DvbS2 Q-3/4 3361 13.2 Under . . 0 Tr G1A1 .
-123.0 Tr 2 981.088 70.9 10.3 80 9.8 11.6 LOCK H ID 11731.088 0.311 Dvb-S 3/4 13240 17.9 285 . . 0 Tr 2 .
-123.0 Tr B2J1 1192.916 64.5 13.6 96 13.1 14.9 LOCK V . 11942.916 0.072 Dvb-S 1/2 1481 13.2 Under . . 0 Tr B2J1 .
-123.0 Tr 3 1025.924 67.4 9.6 76 9.1 10.9 LOCK V . 11775.924 0.071 Dvb-S 2/3 2848 13.3 Under . . 0 Tr 3 .
-123.0 Tr J3J1 1082.416 67.3 12.1 91 11.6 13.4 LOCK H . 11832.416 0.265 Dvb-S 3/4 2894 17.9 290 . . 0 Tr J3J1 .
-123.0 Tr J3B1 1130.116 73.0 13.0 95 12.5 14.3 LOCK V . 11880.116 -0.108 DvbS2 8-2/3 30000 13.3 Under . . 0 Tr J3B1 .
-123.0 Tr E3B1 1267.096 70.0 14.5 98 14.0 15.8 LOCK H . 12017.096 0.274 Dvb-S 5/6 5000 18.0 290 . . 0 Tr E3B1 .
-123.0 Tr C4H1 1202.564 64.3 9.4 75 8.9 10.7 LOCK V . 11952.564 -0.064 DvbS2 Q-2/3 7200 13.3 Under . . 0 Tr C4H1 .
-123.0 Tr 18 1255.700 67.2 11.5 88 11.0 12.8 LOCK H . 12005.700 0.374 Dvb-S 3/4 6000 18.0 290 . . 0 Tr 18 .
Tr 18 67.2 Tr 2 70.9 Tr 4 64.3 Tr 3 73.0 Level
Tr 2 10.3 Tr 3 14.5 Tr 4 9.4 Tr 2 13.6 C/N
Tr 2 80.0 Tr 3 98.0 Tr 4 75.0 Tr 2 96.0 IRD
Tr 2 9.8 Tr 3 14.0 Tr 4 8.9 Tr 2 13.1 Eb/No
Tr 2 11.6 Tr 3 15.8 Tr 4 10.7 Tr 2 14.9 Es/No
Transponders Found: 9
1 2 2 3 3 3 3 4
18
Left Co-Polar: Tr 2 Tr 3 3.6 dB
Right Co-Polar: Tr 3 Tr 4 8.7 dB
Cross Polar: Tr 1 Tr 2 6.3 dB
Format 2.4
Satellite1 -125.0,AMC21
Version 10
Date 06/17/2014
Time 16:50:48
Model TURBO S2
Location
Technician DEE.ANN
Notes
Software 1.34
Serial *******
Level dBuV
Switch None
Meter TurboS2
-125.0 Tr J2A1 1430.040 69.0 11.8 89 11.3 13.1 LOCK V . 12180.040 -0.051 DvbS2 8-3/4 30000 13.1 245 . . 0 Tr J2A1 .
-125.0 Tr J3B1 1355.604 60.0 11.4 87 10.9 12.7 LOCK V . 12105.604 -0.111 DvbS2 8-2/3 2398 13.1 240 . . 0 Tr J3B1 .
-125.0 Tr E3G1 1370.100 67.4 11.5 88 11.0 12.8 LOCK H . 12120.100 0.281 DvbS2 8-5/6 30000 17.9 285 . . 0 Tr E3G1 .
-125.0 Tr B3B1 1405.048 60.5 11.3 86 10.8 12.6 LOCK H . 12155.048 0.329 DvbS2 8-3/4 6250 17.9 285 . . 0 Tr B3B1 .
-125.0 Tr E3H1 1425.096 60.2 11.5 88 11.0 12.8 LOCK H . 12175.096 0.275 DvbS2 8-3/4 4444 18.0 285 . . 0 Tr E3H1 .
-125.0 Tr C4D1 1413.080 60.5 12.2 92 11.7 13.5 LOCK H . 12163.080 0.294 DvbS2 8-3/4 4444 18.0 285 . . 0 Tr C4D1 .
-125.0 Tr C4E1 1419.080 60.4 11.5 88 11.0 12.8 LOCK H . 12169.080 0.296 DvbS2 8-3/4 4444 18.0 285 . . 0 Tr C4E1 .
-125.0 Tr 14 1230.080 72.7 14.0 97 13.5 15.3 LOCK V ID 11980.080 -0.080 DvbS2 Q-3/5 30000 13.1 240 . . 0 Tr 14 .
-125.0 Tr 20c 1362.500 66.0 12.5 94 12.0 13.8 LOCK V . 12112.500 -0.005 DvbS2 8-3/4 8700 13.1 240 . . 0 Tr 20c .
Tr 3 60.2 Tr 3 67.4 Tr 3 60.0 Tr 14 72.7 Level
Tr 3 11.3 Tr 4 12.2 Tr 3 11.4 Tr 14 14.0 C/N
Tr 3 86.0 Tr 4 92.0 Tr 3 87.0 Tr 14 97.0 IRD
Tr 3 10.8 Tr 4 11.7 Tr 3 10.9 Tr 14 13.5 Eb/No
Tr 3 12.6 Tr 4 13.5 Tr 3 12.7 Tr 14 15.3 Es/No
2 3 3 3 3 4 4 14
20
Left Co-Polar: Tr 3 Tr 3 6.9 dB
Right Co-Polar: Tr 3 Tr 14 12.7 dB
Cross Polar: Tr 4 Tr 14 12.3 dB
yes.Are they still transmitting it strictly at the old -20 degree skew only ?
Yep, that's right. So at the switchover, it will still be 'off' the same as was before the switch. They, the networks use dishes with more 'overhead' (excess gain) than the FTA community. Use this with that in mind.the skew a little bit in favor of normality in advance of the total switch over but it's still off somewhat.
AFAIK, there is no 'official' date mentioned by SES or FCC.the official switch over
Maybe it was close to, but not quite, borderline* then, today it's something to cause it to go below borderline. movement, weather?My main boggle is why/how I was picking it up the other day but not anymore.
