Where can i buy actuator cable? Its 4 wire underground cable.. What would it be called.. I cannot find it anywhere online.
Gotcband(wallyhts) has 100 ft of commscope 8136 for 104Where can i buy actuator cable? Its 4 wire underground cable.. What would it be called.. I cannot find it anywhere online.
Yes two motor wires and two sensor wires. I would drop 3 more for a polorotor in the future if you ever decided to add one, no re-digging.
Polorotor is the servo motor that changes polarity on feedhorn systems that use separate LNB. If you are using a LNBF, the polarity is controlled by 13/18VDC voltage and no servo is necessary. You may want to run the wiring in case you want to upgrade to a Corotor in the future.
Okay, ill bite, whats a Corotor?!!?!!
You did that on purpose!!!Okay, ill bite, whats a Corotor?!!?!!
...and who would that be?While I would never recommend Ethernet cable I have never had a problem with sprinkler cable nor have I ever heard of anyone having a problem with sprinkler cable. Too often people who lack actual experience like to make recommendations based on what they think may happen but it's your money and your system so do what you believe is best.
A corotor is like a polorotor but you get c band and ku band on the same feedhorn think of a corotor like a c/ku lnbfYou did that on purpose!!!Okay, ill bite, whats a Corotor?!!?!!
I have never had a problem with sprinkler cable.
