I've been going nowhere with Dish support, so here goes.
We camped for a few days and took our VIP722K along and used an older Dish 500 dish, not the Dish HD permanently set up at home. That worked fine. Now we are back home and ran Check Switch and end up with Sat 1 good but Sat 2 with 3 x's. Before I disconnected the receiver for the camping trip all was working properly at home.
Here is what happened when I tried to run Check Switch to get us going upon returning from our camping trip:
Check Switch results:
Warning 530 - One of the satellite inputs or switches is not connected properly. Normal operation will be adversely affected.
Satellite Input 2 Reception error.
Details: Satellite Input 1
Status = Connected to a DPP 1K.2 w/ separator, 4 ports
Port 1 - Good Connection, Good signal
Port 2 - Good Connection, Good Signal
Port 3 - Good Connection, Good Signal
Port 4 - External LNB - None - No connection
Details: Satellite Input 2
Reception Verified
Port 1 - Good Connection, no signal
Port 2 - Good Connection, no signal
Port 3 - Good connection, no signal
I checked cables, reconnecting, all finger tight, checked again etc. Ran Check Switch several times. Same result. I have the gray Dish HD with 3 separate LNB's. The dish we used camping is a Dish 500 with 2 LNB's enclosed in a plastic cover.
I never touched the antenna wire except to disconnect it from the triplexer that is attached by short coax's to the receiver when I took it camping and reattaching it when we returned.
The only thing I may have done is shorted out a connection when I was hooking up the Dish 500 when messing around with wires at the camp site. Can that cause a problem? If there a fuse to protect the voltage that powers the dish? I saw a small spark one time when hooking the Dish 500 coax.
The receiver keeps telling me that the switch is not functioning properly.
Thanks - John
Reception Verified
Thanks - John
