I have had AZbox MiniMe Americas unit about 24 hours and here are the bugs i have come across.
Now, on the other side, i really would like to like this receiver. It has some nifty features I really like. #1 , it plays the 4:2:2 channels, and #2, i can stream my channels full screen on my windows pc and change channels. I also really like the DCedit program. It makes it much easier modifying the channel names so i don't spend 5 hours trying to do it through the remote control.
I really home the issues above are addressed.
			- Multiple hangs,freezes and reboots when running through menus or doing blind scans.
 - If you go to do a blind scan, switching between C/KU, It will default to KU frequencies for Cband, and Cband frequencies for KU band.  Have to play around to get it finally to show correctly.
 - Dish still moving when doing a scan, so it misses the first few transponders.  Have to basically scan twice to get all the channels.  Ofcourse, this would only be an issue the first time you scan a satellite and their are no channels on it to begin with.
 - Sometimes no audio or no video on a channel.  Have to turn away from channel, back to channel to correct.
 - Blind scan pulls a lot of scrambled channels when told to only pull FTA.  So, then because it takes so long for a channel to come in, i have to sit at each channel for like 20 seconds to be sure it is truly scrambled and not just taking forever to come into the clear. It would also be nice if in the info tab where it shows some channel details, it shows a key if the channel is discovered to be scrambled.  I kept having to click the OK button to see the channel listing menu to see if it was marked as scrambled.
 - on 55.5 degrees, it scanned 80% of the radio stations as tv stations.
 - Slow to turn from channel to channel. It takes so long on some channels it is unnerving.
 - I still don't have recording/timeshifting working and I am not going to play with that again until someone tells me how to backup my configuration settings. Everytime i attempt to play with this, I get a lot of freezes/hang ups.
