no sound on SD channels
Auric3
5
Illinois
New (remanufactured) Dishnetwork VIP211k receiver connected with new HDMI cable to new Hitachi 40" HD TV 1080 (model LE40S508), using a 500 dish antenna (1000.2 antenna installation scheduled in a couple of days).
(The same TV connected to a DP311 receiver has sound OK on all SD channels via RCA connectors.)
The sound is fine on HD channels but there is no sound on SD channels. Googling indicates this is a common problem but I didn't see a fix offhand. I've tried resetting the system, no joy.
Is there a fix?
Go into the setup menu on the VIP211k, and see if there is an audio setting for "PCM". If there is, set it and see if it now works with your tv set.
FWIW I have my VIP 211k set to:
Volume leveling - enable
Decoder - Dolby Digital/PCM
Mode - RF
I am getting audio on all otputs. HDMI, Optical, Line(RCA plugs), and ch3 rf output all work.
Is there a fix?
It sounds like your TV is set to decode Dolby Digital but NOT accept PCM audio. I'm not sure the TV has that capability but do know some A/V receivers (like the Pioneer I have) do. If there is such a setting, the TV should be set to AUTO.
If you switch the satellite receiver to PCM (only as a test), and you loose audio on the HD channels as well, then it must be in the TV somewhere.
The best settings are:
PCM/Dolby
Volume leveling off (This really only applies to PCM audio so leaving it on may be useful. Your milage may vary.)
Mode: Line (RF does some compression, but again only if the audio leaving the receiver is PCM.
ETF I expected but not a charge for this
HOPPER NOT HOPPING
