If you want 4 Hoppers connected to a single dish (w/o wing dishes), is the 1000+ (110, 118.7, 119, 129) the only option?
			And to clarify, a 1000+ is not needed unless you need all four sats.The dish is only to get the satellites. As far as hooking up four hoppers, you are going to need some additional switches. One dish, a couple switches, and a couple nodes.
And to clarify, a 1000+ is not needed unless you need all four sats. A standard 1000.2/1000.4 would be the normal install. The switches do job of supporting the four hoppers, not the dish.
It would require a couple of DPP 44's and or DPP34's. Google the DPP44 and DPP34 switches for their limitations and it should explain how you will have to connect the H/J. Also try googling a multi hopper connection for diagramms.So you could connect all 4 Hoppers in a single network using a 1000.2 or 1000.4 dish? How?
Great. Tx!http://www.dbstalk.com/topic/196687-is-a-3-hopper-install-allowed/
Here was an image I found for 3 hoppers.
Sure, here you go. My kid has moved out so I think I am going to reduce down to three HWSs soon and also reduce down to one WJ.Charles,
Can you also post a photo of your installation that you're using for your avatar. I know you've posted it before, but I couldn't find it. I'm considering going for a 3 HWS 1J myself.
Thanks,
Dave
Yeah, I remember seeing your diagram before -- I figured since you used a 1000+ that 4 sats were needed! What a relief to know that a 1000.2/1000.4 will work just fine. Tx again.Here is my system diagram for four HWSs and a Joey using DPP44 switches. I don't think you will need a Dish 1000+ dish unless you wish for international channels.
Thanks, Charles.Sure, here you go. My kid has moved out so I think I am going to reduce down to three HWSs soon and also reduce down to one WJ.
Wish mine was that neat Charles. Yours looks great.Sure, here you go. My kid has moved out so I think I am going to reduce down to three HWSs soon and also reduce down to one WJ.
