Do you have an antenna or live close enough to receive WKRC over the air? There is a OTA tuner fir the Hopper that will allow you to get CW from an antenna.He just replied to me what Troch had posted. I guess that means Im out. Thanks to all the guys here that posted and tried to help.
The OP claimed it was CW according to his first post.The CW is a subchannel on WKRC 12 (12-2) and is available in HD
WSTR (Star 64) is the My Network affiliate
25 is a low powered station and NOT CW. Now if Directv puts CW there then it just confuses people
http://rabbitears.info/market.php?request=station_search&callsign=wkrc
But as I noted channel 25 is a low powered local station and NOT CW. Now if Directv is using 25 as the CW channel number, then it confuses folksThe OP claimed it was CW according to his first post.
Sent from my SAMSUNG-SM-G900A using Tapatalk
I'm just wondering why the OP assumed it's CW?But as I noted channel 25 is a low powered local station and NOT CW. Now if Directv is using 25 as the CW channel number, then it confuses folks![]()
It is a subchannel of WKRC, owned by Sinclair. Go to sbgi.net, look at the CW affiliates, you will see "CW Cincinnati" and WKRC-2 under it.I'm just wondering why the OP assumed it's CW?
I could see why Directv might, since it could just be an error, But the OP should know if it is in fact CW.
Because it looks like a Sub Channel from what you guys have posted.
Okay so it is CW?It is a subchannel of WKRC, owned by Sinclair. Go to sbgi.net, look at the CW affiliates, you will see "CW Cincinnati" and WKRC-2 under it.
The actual channel 25 out of Cincinnati is WBQC-LD and is NOT the CW affiliate, it is independent. WKRC 12.2 IS the CW affiliate.Okay so it is CW?
And that is where your cable operator or DirecTV puts WKRC-DT 12.2. If you had a TV antenna and scanned in the channels on your TV, you would find CW on 12.2 and you would find retroTV on 25.1.Channel 25 is my CW. Its the only one that has been made available to me. Thats where we watch Flash,Arrow and Supernatural.
I suppose it is academic at this point, but I thought I recalled the OP stating that he couldn't get channel 25 OTA since it is LP, and I was trying to explain and convince him that he could get CW in HD off of a TV antenna if he could pick up channel 12.Not sure why this thread has to be so technical.
if you are someone who signs up for Directv THINKING low powered 25 is on DIrectv only to find out it isn't...thats whoWho cares if the channel number is 25, I don't see CW on dish at all.
really? I guess the cable companies around here must be crazy because the Minneapolis locals (2,4,5,9,11) have been on 2,4,5,9,and 11 for 30+ years nowCable never marks the actual channel to the channel number.
obviously it does...after all the OP wanted CW as part of his localsClearly his Number 25 is CW, whether it's 12.2 or 56.1 it doesn't matter Dish doesn't carry it.
to maybe answer his question??????Not sure why this thread has to be so technical.
