Good question. Do any of the SD channels have 5.1?Are you sure the programming you are watching is in 5.1 on the 722? Very little daytime programming is, not many OTA sub channels are even much other programming is not.
What good is 5.1 with a sound bar ?Good question. Do any of the SD channels have 5.1?
I have the Vizio E601l3EKPB and i know it passes 5.1 because it doing it with my other equipment.I have changed all the cables and everything else i could think of that is the reason i asked if there were a hidden menu that i need ed to set something else are if there was something wrong with this 722
The good book says that bitstream audio must be enabled on the associated TV input (PCM will NOT pass >stereo -- see page 33, top right).I have the Vizio E601l3EKPB and i know it passes 5.1 because it doing it with my other equipment.
Other than the previously mentioned ViP722 configuration for DD, I got nuthin'.Yes i tried all inputs
HBO-E and Showtime East in SD Used to have a DD 5.1 carrier, but I haven't checked recently.Good question. Do any of the SD channels have 5.1?
Have double checked your Opt cable...does is kinda glow red from the end you would plug into the sound box?Yes i tried all inputs
I know of the one that you're talking about and I can't remember what it is called either. I recall that one option is something like "broadcast" and that's the one that works for me.There is another setting on the 622/722 on the same audio menu as PCM/Dolby. I can't remember what it is, but I can check on it when I get home.
