Need to move H3
Bear.3
43
10
Little Rock, AR
My H3 was installed last month and the tech used the existing cable that my original Hopper was connected to. I now need to move my entertainment system incl the H3 to the opposite side of the room.
In order to move the system I will need to add an extension to both my Dish and Comcast internet coax cables.
Here are my 2.5 questions:
Can I use RG6 cable for both extensions?
What kind of barrel fitting do I need to join the extension to the existing cable? Does it have a certain spec?
You want to use a high frequency barrel. Dish uses barrels with a blue inside not clear.
RG6 rated to 3000 MHz is required for the hopper, not sure about Comcast. Some manufacturers label the cable 3 GHz.
Hopper3 and OTA questions
reciever limit
