Hello all, I have a setup question for a DIY'er type. I recently moved (Chesapeake VA 23321) and decided to with the expenses of moving and closing and what not I would save (D* quoted me $250 for the "movers package"...yea...no) by doing my own installation which I cannot seem to get to work.
I brought all my equipment except the dish itself and bought a new SL5 SWM online for the new house to match what was at the old house.
D* setup tells me I need to be at 40 Elevation, 228 Az, and a tilt of 64. I made sure the mount was level, and set the Elevation and Tilt based on the markings on the mount itself, the Az I just used a compass and must be pretty darn close to 228.
I wired it such that the power module is on a 25 foot RG-6 from the dish to the LNB power output and then another 25 foot from the power module using RG-6 to the back of the HR24. I have zero signal on any of the transponders so being that I am new to this I figure I obviously screwed something up. I do NOT have a splitter between the dish and the receiver, only the power module is between them.
Does the Az have to be exactly spot on to get any type of signal or as long as im in the ball park should I be seeing some faint signal from any transponder? Also does my cable distances have anything to do with it from the power module to the dish/receiver? I am stuck and wanted to exhaust my options before I call up D* and fork out cash.
On a side note I DO have the green splitter with the power pass through.....I think in writing this I just found my answer...maybe....I am guessing the power module doesnt pass signal to the receiver and that you must use a separate output on the splitter to the reciever...just a guess.
Thanks for any help you all can provide!
to Satelliteguys Jeff Stone!
